Lux model 30/XXX tools
@floor-a-matic
YES, I'll definatly buy it from you, Thank-you. Drop me an email, and we can figure how you want paid and I'll get the money to you for the brush and shipping.
thanks,
Bill
another question, LOL
Does anybody have an extra "saddle" companion for a model 60 they would like to sell? I've got a 60 coming with a set of tools, but no companion. Ill post a pic of it when it arrives too. (it might be an LXI, but I think it's a late LX). Alex, thank-you for the complement on my 30. I've passed up alot of them in the last 25 years, just because so many of them have been used, abused, and just beat to hell, and I wanted something in a little "nicer" condition to start with. I was very fortunate to find this one. It cost me less than 75.00 with shipping.
Hi powermate1970.
You need a Companion for the LX? well I've got one that you can have. It's the type with the holder for the narrow space cleaner (crevice tool).
Glad to help.
Alex.
Alex!!!!
sorry for the late reply. Have my dad and grandson both in the hospital, so it's been really hectic around here. Thank-you for the offer of the "companion" I would be more than happy to buy it from you. I received my 60 in the mail today, but I have some questions about it, as it is my first experience with this model. If you could shoot me an email, I would really like to ask you some questions about the "automatic" workings of this machine.
thanks,
Bill
Hi powermate1970.
I just sent you an email re. the model LX companion, let me know if you got it.
As for the working mechenism of the model LX, this is not my expertise, but the history of Electrolux is. (Kirby too) I also have a short history of the vacuum cleaner, if you want them let me know.
Send me an email at [email protected]
Alex
The LX Vacuum Cleaner is fairly straight forward; simple to take apart and adjust after you've done one.
The LX is extremely robustly engineered, there's very little that can break and refurbishment is easy.
What a giggly treat when the slide is aligned & lubricated, mechanical adjustments tuned up and the bag shoots out 10 feet - and more. :-)
The only thing not in this picture are the many differing length and size screws and bolts. I always insert them in a cardboard card to keep them getting mixed up.
The Magic Brain components are easily understood and require little maintenance. The biggest problem on an LX is the deterioration and possible disconnection of the vinyl air tube running through the door hinge to the intake's pinhole bleed.
Modern vinyl aquarium or rubber tubing replacement resolves this in a jiffy
The yellowed tube that connects the the bag door nozzle bleed to the main diaphragm trigger...and runs through the door hinge has usually hardened and cracked, disabling the Magic Brain action.
Replace this tube with an exact length new one - after cleaning the impacted dust from the bleed hole - and 99% of the time the LX performs flawlessly.
Dave
The Ejection process.
While I know this rather well I'm not an engineer. Can you discribe what causes the LX to eject, and what all those springs and levers do in that 5 second process. A lot of Electrolux buffs out there don't have a clue.
Thanks again,
Alex Taber.
Spray gun question.
Do any of you find it odd that the top to the model LX's spay gun is blak bakelite? That looks of strange! I mean, it should have been the same color as the polisher attatchment. Perhaps the engineers thought this was not going to be used, but even so, it should match the machine. What do you think?
It would probably be easier to explain in a hands-on demonstration with props...or you could wade through the Engineer-speak on the patent applications or the Serviceman's Manual.
But I'll give it a KISS shot. (Keep it simple, stupid)
When the bag spring and attached bag 'sled' are folded and latched against the back of the bag chamber with a genuine Electrolux bag with sealed edge inserted, the bag/hose door is latched closed against its spring catch.
According to pre-set launch settings, when the pressure differential created when the motor and fan are spinning suction between the bag chamber and the bleed hole inside the hose coupler intake goes past a certain balance point due to accumulation of dust within the bag closing up pores, this differential exhausts enough air from a large rubber diaphragm that pulls down a floating lever connected to the bag door latch and the launch sled rail.
The door opens first on its coil-sprung hinges and drops flat to the floor at the same time that the interconnected power switch is flipped to OFF by a toggle wire.
The dust-clogged bag now being sealed by residual suction to the rubber seal bag compartment rim, as the motor winds down the suction holding the bag in place lessens to the point that the spring latch, now in a half-cocked position, releases the powerful flat folded spring and shoots the bag support sled down the rail to its stops flinging the loose bag out of the machine.
My record fling was achieved by filling a dust wrapper with a carved styrofoam block, btw)
Each of these automatic actions has a external mechanical override lever so that the door can be opened or the bag ejected with the LX unplugged from the wall socket.
On the first generation LXs without the control dial the single setting was established at the factory then fine-tuned in the purchaser's home.
It was found that different above sea levels and particulate size of the household dust environment could cause the ejection to happen prematurely - Oh My! - before the bag was at full capacity, or not at all after the bag was beyond full.
The quick-fix solution from the Factory or Dealer was the Attic & Cellar Key that jammed the release lever to maximum bag fill.
These keys are scarce as hen's teeth but that's ok since most early LX's were retrofitted by the Servicemen with the control dial mechanism.You were advised to store the key under the power cord plug door on top of the machine. Not all LX's came with the cord re tractor - it was an up-sale option.
The 2nd generation aluminum (later plastic) rotation dial addressed this failure to adapt to the various dust properties throughout the same home so that bags were not wasted unnecessarily and Milady could adjust the trip action as she pleased, from outdoor to basement to main floor to attic, from sea level to Denver heights.
The final version of the LX (model 60), the LX1 (model 61), added features such as rear wheels on the runners and a flip sideways cord winder so that one didn't have to unscrew & remove the cordwinder to access the blower port.
Whew! read over several times.
Dave[this post was last edited: 1/18/2013-17:17]
Thanks Dave.
In all my years of working with the model LX, I never knew the term for that flat thingy coiled up, and used to push the wrapper out of the dust chamber. Now I know, it was a 'sled!' There are so many terms not know by most of us, and yet, we know the machine better than the backs of our hands.
As for the picture, yes, I have this, and am glad you shared it with those who don't know the model LX like we do. However, I find it a bit disapointing that the person responsible for this photo shoot used this model which is a LXI (61) and did not use the LX which had the name Electrolux in red lettering on a yellow background, far more impressive from an advertizement point of view.
And you can teach an old dog new tricks, because I never knew the winding down of the motor caused the rubber gasket to trip the latch under the diaphram, and activate the sled.
Do I have permission to use this discription in future referances to the LX updates of the History of Electrolux? I'm planning a much longer version in the near future.
Thakns again.
Alex.
What were they thinking at Electrolux?
Wouldn't it have looked more impressive if that model LX had been outfitted with the companion and all the attatchments? This was for Good Gousekeeping, Life, and Look magazines. Shouldn't they have shown the LX in all it's glory?
Fine tuning process.
Dave' you mentioned that the first generation LX's were fine tuned in the customers home. My model LX has a tiny belly button like thing just below, and slighly left of the lever to open the front cover. Was this were the salesman pre set the mchenism, or is that just a nick in the front cover?
I've read your discription over several times. Awesome! Thanks for wording it so well.
By the way, do you know the history of the Electrolux Corporation. I've written several versions of it, but the earliest is on of the best, as i also follow the k.i.s.s. metheod. If you want a copy let me know.
It might have looked more impressive but Electrolux Marketing chose to show the concurrently available bare sleek machine tossing out a bag. That was the focus of this expensive advert. The ad dates from 1954 and the coloured plastic inserts were no longer available.
Resides the Companion was an up sale option.
I don't believe I've seen a color print ad for the first LX other than the 1952/53 Owners Manual.
Remember also that this double page print add was for the second edition LX with plain stainless steel trim plates, another bean counter directive in exchange for the dial, I'm sure.
Dial-less LXs are the hardest to find because of Electrolux's diligence in hunting them down and fitting the dial.
The model LX Model 60 was introduced in 1952, the plain side LX appeared new in 1954 with the control dial (which was widely retrofitted to the early models, and the LXI was introduced in 1955 with wheels on the runners, a newly designed rug nozzle that was partly made of blue plastic, and the very last of the LXIs had blue-plastic dusting brushes and upholstery nozzles. The LXI was produced for less than a year as the lightweight Model E came online with the same new tools and the combo upholstery/dusting brush.
That's what the decades of research tells me and that's good enough for me.
I simply cannot call a 2nd generation LX a model 61 LXI - it's not stamped under the strap handle trim piece plates of either of my 3 nor have I seen the stamping on anyone else's unless they are genuine 1955 LXIs...
Dave
(My apologies for hijacking the original Lux model 30/XXX tools thread but after Crevicetool's contribution it seemed fitting to do so. I had no idea it was going to gallop to such length for what should have been a separate LX/LXI thread.)
This is the Service Technician's Kit for adjusting the first version dial-less LX in the customer's home or on the bench. It requires the unbolting of the pneumatic unit with the door attached. 3 bolts, iirc.
The 14 page illustrated booklet is excruciatingly comprehensive.
[this post was last edited: 1/19/2013-01:31]
The vacuum cleaner that started my collection.
Many times over the years I've told the story of how it was the Electrolux model LX of a dear friend that started it all. But I've never told the full story.
As I've often said the lady who owned the Electrolux was Jeanette Pletincks, and she was like a second mother to me. I've also told how I made a pest of myself, waiting to see it 'pop.' When I started working for Electrolux in 1968, my first demo of the new 1205, was to Jeanette. My secret hope was that she'd buy the 1205, so I could keep her LX. No way, she did not buy. She kept that Electrolux to the day she died, which was in 1985. By then I'd moved to Naperville, Illinois.
One day, a few months after her death, there was a knock on the door, and there was a UPS driver. "I have a delivery for you" he said as he handed me a huge cardboard box. "You must have the wrong house, I didn't order anything" I said. Then he said, "It says Bobby Taber!" I was only Bobby to a few people, so I took the box. Inside was Jeanette's LX, the only thing not original was the cord winder, seems the original's spring had sprung and was replaced. But there it was What I did not know was that back when I was a kid, Jeanette had told her husband that this LX would be mine.
Needless to say it went into my display, but befor that I used it to create my own version of the inside of the instruction book. See what you think.
