Lux 5000
fantomfan57
Austin Texas
Scored a nice Lux 5000 this week. Lady said it needed a new hose. Before I picked it up, I was already pricing hoses on Ebay.
Got it home and decided, with the help of Google, to explore the hose handle. I found the power switch had some scoring at the terminals. I found a replacement in my stash (exact) and reassembled the handle. I hooked it directly to the PN and it worked! Even though the switch may have been the problem, I wondered if the source was the wands or PN. I have already taken the wands apart and found no problems except a bit of scoring (not melting) on a couple of male contacts.
I will mention that the female ends do have a tab that can be gently bent, to ensure snug contact.
To eliminate the possibility that a problem may be with the PN, I will be inspecting and cleaning it this weekend. Then I will clean the entire vacuum thoroughly.
I really love this stuff!
Thanks Fred...
Just finished cleaning and checking the PN. I am cleaning the vac and will try it our Sunday.
I stopped because I needed to spray vinegar in the bag chamber. Has to dry (kills germs and smell) before I try it out Sunday.
Already looks great after having be wiped down with rag with mild detergent followed by some 91% alcohol and a magic eraser.
Works great!
Before I ran it, I grabbed a big bag of Kirby cloth Hepa's from Crucial Vac that I have picked up at Goodwill for $2.99 and cut the bottom off. I then inserted it into the Lux chamber, grabbed a regular Elux vac bag. I cut 3/4 of the bag off, fit it down into the Hepa, making sure they were sealed in. Left the extra Hepa in place and ran the vac.
The results was still a strong suction and virtually no dust escaped.
Of course....
I only used the Hepa's because I got them cheap. Unless I can find them cheaper, I will just snatch up any that I think will work this way.
Once I get my Vita-Vac assembled, I will be trying out some Oreck Hepa bags. Got those for a song at a Goodwill a while back.
I like the idea of using the Simplicity F bags for my Air-Way & Vita-Vac, but I don't have any and they are pricey.
Fred....
actually I got the idea from Tom Gasko and later Andy R. for use with Air-Ways. But instead of using the Simplicity Freedom bags, I will use what I have and then find a source for less expensive cloth hepa bags.
There may be other vacuum applications. So if you see a cheap package of bags, snap them up. You will definitely save some money as they are pricey.
The balance is using a hepa bag and wanting to discard it as soon as you can to prevent smelling up your vacuum.
Not sure what others have used, but a small trigger bottle with white vinegar does wonders (after the vinegar smell dissipates).
Vacuumland's at its best when people like you, Tom, and Andy share their knowledge.
Being economical & health-conscious at the same time is a win-win.
Thanks again, Garry.
