thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 21, 2015 #21 The main cover off revealing the transmission, motor and tech drive.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 21, 2015 #22 Inside the fan housing.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 21, 2015 #23 [No message]
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 21, 2015 #24 Motor spindle off, and closer view of the fan.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 21, 2015 #25 Fan off showing the front bearing.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 21, 2015 #26 The underside of the fan, quite a lot of dust build up.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 21, 2015 #27 Continuing the strip down.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 21, 2015 #28 Closer look at the Tech drive power assist.
super-sweeper Well-known member Joined May 8, 2011 Messages 3,627 Location KSSRC Refurbishment Center Nov 21, 2015 #29 Gross, haha! Keep us posted!
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #30 Tech drive out
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #31 And motor out, revealing the bare shell.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #32 What a mess, anyway time for a bath
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #33 A hot soak does the world of good.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #34 The water after.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #35 Bath drained, quite a bit of sand and grit in there.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #36 Everything drying, now on to the motor.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #37 Now unfortunately my phone died during the motor strip down process so this is the only photo I have, however the motor was stripped and any parts that could be washed got washed, everything else got lubed up to make it run all nice and smooth.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #38 completed motor, polished casing all ready to be re assembled.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #39 Motor sitting in its fresh housing.
thekirbylover Well-known member Joined Mar 27, 2012 Messages 959 Location Warrington, cheshire Nov 22, 2015 #40 The tech drive also got the spa treatment, this was dis assembled greased, cleaned and then re assembled.
