How do you resolve the problem of the toe-touch control (front wheel bracket shaft) going down all the way when you attempt to adjust downward? Could it be a problem with the ratchet teeth or with the ratchet spring?
I am presently facing this problem on my 1972 Classic.
One solution I might think of doing would be to stretch the spring but slightly. Another would be to get a new ratchet spring (1331).
What do you guys think is a long-term solution, other than replacing the front wheel bracket shaft?
