Kirby motor bearing
glen86
Ohio
Hello, I'm currently working with a Kirby Sentria 1 and I'm replacing the bearings. The rear motor bearing is double metal shielded. But a supplier sent me a rubber-shielded one instead. I am going to call them back about it. But I never did find out why Kirby chose to go with a metal shield on the rear. I only assumed it was for durability purposes. But can someone explain why they chose metal over rubber? Thanks.
Well...
From what I've read the metal shielded ones are better for high speed environments due to the heat conductivity of the metal. Where rubber gaskets are better for keeping material out of the bearings like dirt or water.
You can use either or in many cases, it seems. I tend to use rubber ones for water filtration machines or in machines with terrible filtration at least on the front one.
its time kirby come out with a new model. Sentria 4 is well over 5yr old and its time for something new to come out, even if its another G-series (sadly).
