Kirby G6 Shampooer.
I am fairly sure it will.   There hasn't been much change in the Shampoo/Renovator attachment until the Avalir system for bare floors.   I am thinking even that system will retro fit to older G-series machines, because I have received emails from Kirby offering it as a upgrade to my UG.
Now I could be wrong, often am,  if so someone will correct me.
The fact is: That all Kirby Shampoo attachments from the G5 all the way up to the new Avalir Complete floor care system will work perfectly with your G6.
G to CIII
I'll say no.  The air horn (exhaust) is configured differently, horizontal for the Classic III, Vertical for the G series.  The safety speed selector switch is in a different location.
Kirby Avalir Multi-Surface Shampoo System
The new Kirby Avalir Multi-Surface Shampoo System will <span style="text-decoration: underline;">NOT</span> work with any 1st or 2nd generation Kirby (C/R models through Legend II).
I don't believe it will work with Generation 3, G4, G5, or Gsix either.  The safety switch position changed slightly from at least the Gsix (I once had a Gsix that got sold to me with a Generation 3 air-intake guard and it DID NOT fit because the safety switch actuator did not touch the safety).
I know <span style="text-decoration: underline;">FOR SURE</span> it works with Sentria II, and should therefore fit Sentria as well. I have an Ultimate G Diamond at home and the Avalir Multi-Surface Shampoo System, I have never thought to see if they fit together. But according to member sptyks,  they will fit!  Woohoo!
