HI
looking for some advice for my Kirby 519 nozzle and figured this would be the place to ask
The Nozzle doesn't seem to hook on as tightly as it should. It's actually been this way for a long time. if I mess around with it or sort of shim it up with cardboard or part of a Zip tie. I can usually get it to at least make good seal on the fan case but the bottom nozzle hooks usually come loose and I have to fix it again.. The Gasket could probably use replacement but thinking maybe the hooks are worn out on the nozzle. is there a way to fix or tighten up these hooks ? or should I start looking for a replacement nozzle ?
I did try using the Nozzle from my DS50 and it does hook on tightly as it should . but of course the safety switches are different and the 519 won't run with ds50 nozzle. Ive attached some Pics and the last two pics are with the ds50 nozzle to show the difference.
If I do have to find a replacement Nozzle, what models where compatible ?
Just a little background on this machine.... it originally belonged to my grandmother. It has an insane amount of running hours on it! so much that the motor was rebuilt in the early 1980's at a local vac shop/ Kirby dealer.( new armature and bearings/ newer style front bearing plate) long story short, it was run several times a day, every day from 1965 till roughly 1992. and yes she bought it second hand in 1965 because she couldn't afford the latest model.
