The VAcuum is not a 505. I can tell from that picture.
I'd say 509 maybe probably not. 510_512 maybe early 513 the version with 3 amp motor.
It has 510 motor housing. The motor might be 4 amp looks fatter than ,,3 amp.
Texaskirbyguy is right its bars looked longer. The armature blades on 3 amp are triangle shaped. The 4 amp have almost rectangle with triangle corner cut out.
The body looks like 510 but you have,505 508 or 509 emtor.
It's basically mismatched parts.
510 motor housing but 505 508 emtor. You didn't show inside nozzle but guess is 510 to 512 replacement belt lifter that was red and grey.
The best you can do is keep it as is. Trying to part together vacuum back to original of any early version is almost impossible.
It's a nice blue it runs. I wouldn't bother much more than shiing up and use it or display it. I love blue but that is what I would do.
