Kirby 1CR armature/shaft moves horizontally
superocd
PNW US
If you pull on the shaft the cooling fan behind the bearing plate touches the bearing plate. Bearings are new. What gives?
You need the 1160 bearing for the front and the shoulder faces toward the cooling fan as shown in the picture below. They have since updated the bearing plate to use the newer style bearing found in the Omega all the way to the G-Series. The 1CR was the last Kirby unit to use the shouldered bearings.
