James Dyson: "The EU should spur invention, not mediocrity"
Quote:
"but I think that if a vacuum cleaner needs to clean exceptionally well and consume less than 800 watts, then it will need to be of a "Direct Air" design like the Hoover Convertable or the Kirby."
"I wasn't trying to push one type of vacuum over another. It doesn't matter if it's Clean air or Dirty fan and wattage doesn't matter as long as it has sufficient power to thoroughly clean a carpet."
Ok...bit of a contradiction.
As proved by the 2 video's above showing 2 clean air machines rated at 560w and 550w respectively, a clean air machine under 800w can produce enough suction power to effectively clean a carpet, which is the whole point of the new legislation as too much power is being wasted.
There may be many on here who share the same opinion that a carpet can be clean as it can be.
Others may share the opinion that as long as it looks clean, then it is clean.
However from the first thought you'd have to vacuum every day once the dust settles from the night before. There is no way out of this unless you live in a home where you have a dehumidifier that shifts the moisture out of the way in each room AND also cleans the dust in the air. Short of living in a vacuum with your own air supply is as 100% clinical as you're likely to get.
It is impossible to keep carpet 100% clean 100% all of the time.
OK, if you need clarification, sufficient power to thoroughly clean a carpet in my opinion is at least 600 watts with airflow of at least 115 cfm along with a brushroll that sufficiently vibrates the carpet.
As far as your video goes, almost any vacuum over 300 watts can lift the edge of a one square foot piece of carpet. Just because a vacuum can lift the edge of a very small piece of carpet, doesn't mean that it can pull the air through it along with deeply imbedded dirt.
Mind over matter
It comes down to what worries us the most. Physical debris on a carpeted surface does not bother me unduly, indeed it is the sight of it which troubles me the most, rather than the knowledge it exists at all.
As I said already, another school of thought says that at least carpets hold debris in place until such time it can be cleaned, unlike hard floors which allow it all to become air borne and ultimately breathed in. Even though we only ever had floorboards in the upstairs rooms of our home, my mother had a carpet square under each of the beds so as to trap dust which moved around.
My mother ran a very clean home, indeed for many years worked as a private housekeeper for a number of people. She had a theory that the presence of dirt on a carpeted surface was more an indicator of a poor housekeeping regime in general, rather than a health-hazard in itself. She didn't like the look of it any more than I did, but like me she was more keen to ensure the surfaces which we slept on and ate off were kept scrupulously clean and fresh.
Call me crazy, but I'm of the opinion that if a vacuum cleaner has enough suction to pull a whole piece of carpet up off the floor, then it has more than enough suction to pull tiny particles of dust and dirt out of it.
Sptyks, being perfectly honest, I think you're being deliberately argumentative. Even when presented with video evidence of strong suction and carpet agitation generated with under 800w of motor power, you're arguing the toss. And seeing as you haven't used any of these machines and haven't been a part of the market they were sold in or been in day to day scenarios where they would be used, quite frankly, I suggest you come back and have this conversation when you have. [this post was last edited: 6/24/2014-13:19]
Don't worry, Benny. I know you've been in the business long enough to know your stuff. And you were around in the days of lower wattage, clean air vacuums and will of course remember that there were high performing, low wattage, clean air vacuums.
I don't think vacuums clean any better or worse, generally speaking, than they did 30-40 years ago, I just think the methods of getting those results have changed
It is an interesting point, as the lower wattage upright cleaners did clean well, but then they also let out a lot of dust too, at least those with shake-out bags did. Add to this the inefficiency of the tools which meant homes might not have been cleaned as well as they are today.
The whole thing is a medley of changing situations, such as the fact that years ago we had less traffic pollution but much more from manufacturing and open fires in homes etc. But homes were also more draughty too, which was not always a bad thing as air circulated well, unlike in the modern home with it's super insulation, where the occupants live, cook, wash, sleep, smoke, and break wind into the same air hour after hour.
Our modern lifestyles means the household of today has a number of new health hazards within them, but the % dirt content of a carpet pile has to be one of the least worrying aspects. For me, fire has always been of great concern as I know of a family who perished in such circumstances. All the new exciting appliances we own today bring with them a new fire hazard, as do the cheaper, thinner, imported extention leads. But these are of course not the only sources of ignition. On the contrary, I have yet to hear of an unclean 80/20 berber falling foul of spontaneous combustion.
YIKES!!!!!
I WILL say........ GOOD filter paper is esential for our bagged vacs. The bag plant #2 (HOOVER) Company, made quality bags from QUALITY paper since 1952.
Anyone who ever used those bags can say that the paper was of supeior quality. HOOVER even made bags for 'other species'. I'm not gonna throw gas on the fire, but, good fliter bags "clogging" is nonsense! On the packages and in your owner's manual,{I'll wait while you go to your books and/or machines}.......................Ok. clearly states, (Feel free to all read along), Fine materials like face powder,plaster dust,etc can seal the bag early. When using your cleaner for this purpose, it is suggested that you change the bag more often.
Our beloved bagged cleaners work just fine.
I'm just sayin'
Yes but in the UK (and whether or not it was a claim used in the U.S) Hoover proudly promoted their disposable dust bags as being reuseable, thus saving on cost.
What a pity they forgot to leave out that the dust bag can maybe be used a second time after shaking out after the first, but definitely not a third or fourth time because of clogged pores.
Just a quick comment
.... With special reference to replies #18, 48, 49, 51......
I doubt that the 'new generation' of cleaners will run any cooler, or be any more reliable. Manufacturers will just use the new regulations as an excuse to market 'smaller/lighter' vacuums with (even??) less metal in them, as they shrink the motors in size to save materials, bus still run them at the same (ridiculously high) energy density and therefore temperature. The trend for years has been to make ever smaller motors running at ever higher rotational speeds in order to achieve the same suction. Higher speed = shorter life, unless some radically new bearing materials are used. Most vacuum motors still use a bronze bush at one end and a tiny roller bearing at the other (AFIK), and after a couple of million revs both types are 'toast'. I did once try to get into a Dyson motor to lubricate it, but discovered that the case is spot-welded together, making maintenance impossible... :-(
.... Which brings us nicely onto 'planned obsolescence'. Nothing built now for domestic use is intended to be dismantled for maintenance. Here in the U.K. we have seen 'Do not open - No user-serviceable parts' on appliances for the last 30-40 years, along with heat-sealed cases to further make the point. If the E.U. 'godfathers' REALLY want to make ecological improvements, they should be legislating to require ALL appliances to be fully repairable, and have a minimum service life (with reasonable maintenance) of (say) 20 years. Anyone manufacturing appliances (of any type) which fail to last such a lifetime should be heavily fined (listening, Mr Dyson, et al??) in order to pay for the cost of early recycling. ;-) Of course, this will never happen, as the collective E.U. Governments make too much money from the sale of new goods.... :-(
I prefer carpets to hard floors, which just allow dust and dirt to blow around, and for me the test of a clean carpet is to whack it with the palm of my hand when the Sun is on it.... No visible puff of dust = clean enough.
Excess technology, and the 'brain' mistaking drag for a 'jam'.... I posted elsewhere about the lack of need for anything on a vacuum cleaner apart from the on/off switch.... ;-)
Please feel free to discuss.....
All best
Dave T
Robert ...
"Our washers use 1/3 to 1/4 of the water american machines use and we get better wash results."
No you don't. Not by a long shot.
I beg to differ. Not to get into the great front-loader/top-loader debate, but both machines are 2 different methods of achieving the same results. The main difference being that TL's don't heat the water and require far more additional chemicals and stain removers to achieve the same result as an EU frontloader does with just detergent.
Um.. sorry to disappoint - the Hotpoint TL I had in the 1990s had a water heater built in. Obtaining a new element for it was very difficult, looking back.
Also the current LG top loader my relatives have in India ALSO has a heater element.
Again, no ...
"The main difference being that TL's don't heat the water and require far more additional chemicals and stain removers to achieve the same result as an EU frontloader does with just detergent."
You're alleging that EU frontloaders "achieve" the same results as American toploaders; they do not. In my experience, at best, what you get with EU frontloaders is a mediocre clean surpassed by even the most mediocre top loaders.
Main problem is UK families don't really know how to cook, clean, and wash any more. It has all gone by the board. Feel free as grown men to argue the point from behind your keyboards, but try not to take it all too seriously. Life is a very short commodity.
Yes, Benny, I was referring to US Top Loaders. The old UK Hotpoint TL's had heat settings the same as the FL's.
NYCWriter, bold statements considering you use a TL at home. I'd love to see some evidence of this, seeing as you apparantly think everybody in Europe is walking around wearing dirty clothes.
Speaking from experience of using a US TL Whirlpool in a previous job to wash kitchen cloths, table cloths and seat covers when I worked for a local childrens activity centre, that machine never got a damn thing clean. It would leave stains and nothing smelt fresh. It was much better to take the washing home and do it in a proper FL. It was eventually replaced by a EU Miele Little Giant, which got everything clean.
I'm not blaming this on the machine. The combination of that type of machine and a European detergent just didn't work. If we were using a US detergent and all the additional products that are required to go along with it, I'm sure the results would have been fine.
As I said, growning up in a house with 4 kids (3 boys) you can imagine the level of washing and the stains involved - food, mud, grass stains, paint, pen etc. You name it, we washed it. And yet they always came out of the machine clean with no need for additional chemicals and stain removers in the load. Unlike a US TL with no actual heat setting that requires additional chemicals just for basic washing like keeping sheets white. [this post was last edited: 6/26/2014-04:48]
Actually Benny, following on from last night's Watchdog consumer news slot, it would appear that most of the UK can't be bothered to shop properly, either. Most do online food shopping, which I have never done, as of yet.
Two of my friends who work (one who is part time, the other full time but off at weekends) have also announced at the age of 30, they're both hiring cleaners to come in as they can't be bothered to clean home. Neither of them are married, but both are blokes who simply can't be bothered.
Seems like I must be of very few who loves to do things the old fashioned way. Lemon juice, vinegar, "how to clean by Kim & Aggie" cleaning bible, steam mop and a handful of vacuums I get to use myself.
^I remember when I first left home 6 years ago, a friend of my then flatmate also left home for the first time around the same time as us. He hired a cleaner, lived off take aways and took his washing home for his Mum every weekend. WHAT. IS. THE. POINT?
There's 2 of us at home. Both work long hours. I leave home at 7:20am, and don't get home until between 6:30 and 7pm. Ro has a more flexible schedule because of the nature of his job, but that also means he can sometimes be out late into the evenings or have to be in work early. We still manage to do what we have to.
It's pure laziness.
Washing Machines...
We all know that this is not necessarily the case.
Turbo500: Maybe you should refrain from posting on this subject until you get all your facts straight.
I have to stay in a Navy Lodge from time to time when on travel to San Diego. The laundry rooms have a line of expensive top of the line front loading washers and dryers. I detest the washers more than I can possibly express. They simply do not rinse the detergent out of the clothes adequately, and they leave suds on the inside of the machine that are impossible to avoide touching your clothes as you unload them after washing. I am careful to measure the detergent and not use too much.
My old 90's vintage Maytag top loader at home does a far better job of cleaning my clothes, never under any circumstances leaves suds after the final rinse and only takes half the time of the top loader to do so. Why any washing machine requires a full hour to wash a load of clothes is beyond me.
I also detest that once started, you cannot stop the machine and throw in something you neglected to put in the load before starting. I will never, ever, under any circumstance own one. I will find ways to keep those old Maytags running. Parts remain readily available.
The popularity of front loading washing machines completely escapes me. It is another uninformed trend like bagless vacuums that needs a stake driven deeply into it's heart.
My experiences on travel in Europe was that European washing machines did a lousy job of washing clothes. Whenever possible I tried to use a laundromat on a US military base if there was one near where I was traveling. They generally had US sourced commercial washers and dryers, not European machines. One washing machine in particular at a German guest house left all of my clothes a near uniform grey color. I wore them but I wasn't happy.
$599 list price for a Kenmore Elite Intuition canister vacuum and it might last four to five years before something breaks or fails that is beyond economical repair. That's a lot of money for that kind of throw away junk. Everything about them feels cheap and nasty. The Chinese motors in them are kludge, nothing like the stout double ball bearing Ametek Lamb motors Kenmore used to use.
To get something with the sort of durability one used to expect from a Sears vacuum you have to pay four figures for a Riccar or Simplicity, or darn close to four figures for a top of the line Miele. And even then, I don't think the plastics will prove as durable as that of a 1980's or early to mid 1990's Kenmore.
pure laziness
That is as may be to an outsider, however, to the person who has the disposable income to pay for it, if they can get a good service provider, it's win-win. It is also very good for the economy as it means it helps keep people employed. I have to say I am all for -and always have been- paying someone else to do a job which I don't like doing. As long as there has been the means to pay for it -for instance the opportunity to go and work for the money- I've generally paid to get work done for me. Someone who is better skilled and enjoys that job will always do it much more efficiently.
I have a professional cleaner now. I see hiring her as no different from using a dentist, plumber, decorator, and doctor. It's all about perception.
Ok, the great front loader vs top loader debate is never ending.
As I've already mentioned, we had a Whirlpool TL at work. I also had the misfortune of using a Speed Queen TL whilst traveling in Europe a few years ago. And the Maytag's at my sisters uni. I found them all excessively large and unnecessary, used too much water and the results were average, at best. Needlessly wasteful. Although the Speed Queen was probably the least offensive.
I've never seen a US TL with full temperature selection - just "cold", "warm" and "hot". Not even adequate IMO.
Seeing as this debate really isn't going to go anywhere (just like it hasn't done for the last god knows how many years on Autowasher), lets get back on topic, shall we?
Apart from SEBO and Hoover with their TP2/3 series, has there been any other upright on the market which has a motor filter on top of the hood before the bin? I'm just wondering about this, with talk about filters and what Benny refers to in his last response regarding some vacuums that have low power and still put out dust, in particular vacuums of old.
Im also wondering and from where I have seen it - cleaning tools that have vents in the recesses of a machine, where the suction air takes the dust off the cleaning tools when they are stored on the vacuum cleaner.
