I guess it was about time to replace the air purifier filter...
WOW!!!One REALLY dirty air filter!!!!I vacuum the outer filters on my 'Lux units every week.Yes,gives an excuse to use the vacuum.The air purifier machines--the HVAC filters now last for MONTHS!!!By the way hows yours??I have also seen similar filter elements in Cat genset engine filters that bad-but the engine still worked!The filter element is ahead of the engine turbocharger.Amazing how much suction an exhaust powered turbocharger can generate!After all it is like a GIANT Kirby fan!The 3816 series Cat engine our genset at work has two large turbochargers with giant pleated air filters.Yes,like those in purifiers-just bigger.
Wow, it's quite frightening to think that all that could end up in your lungs if it weren't for the purifier!!  Maybe that's why I'm always coughing...
I have this model ... see photo. I change the carbon pre-filter every three months per mfgr instructions. The inner HEPA filter is permanent and only needs to be vacuumed, which I do when I replace the carbon pre-filter.
I've never heard of a permanent filter for those Honeywell HEPA air cleaners. I have a Honeywell too, but its an older model. I usually change the HEPA filter once a year or so.
Wow, guess if you don;t have an air filter that's what goes through your lungs.
I just got 2 used Austin Heealthmates a old Healthmate & a older 200HM Jr.
Bought the big one an allergy filter as the original Austtins had smaller filters & the other one came with a good allergy filter. Spent $70 for the 200 & bought the other for $45 but the filter cost almost $200 with a discount. So over $300 to help clean the air but I guess its worth it & those filters can last up to 5 years but you do have to vac that prefilter...Goodness this is a vac forum...use it....LOL
I'm on chemo now & was getting a bad cold & coughs so I figured I better filter the air.
