vinci
I have a Rainbow E-2 single speed that I'm rebuilding. I need to replace the top and lower bearing of the motor (G type). The cooling fan won't budge. It sits on top of the shaft and I'm counter holding the shaft with an 1/8 hex bit. Is the fan supposed to be turned counter-clockwise or clockwise? For the old D series Rainbow the fan is to be turned clockwise to remove, but not sure about the E-2 series. Also, how is the bottom plastic removed so that I can access the lower motor bearing?
Thanks for any pointers.
