Rainbow 2 speed motor
gmarquez
Active member
Central California
Hi everyone, I’m about to start rebuilding the motor on a two speed rainbow and was wondering if anyone knows how to remove and reinstall the bearings for the motor. Like if I’ll need a bearing puller or a press to get them back on. Thanks
Lower bearing will come off with the fan housing, upper bearing unless held on with a nut, will need to be pressed off or pulled with a bearing puller.
And don't forget the anti-static mat and be sure to hook your little finger to it as well - or you can fry the circuit board/controller. Seriously. All Rainbow authorized service centers are required to have one.
