How rare is a Hoover Lark Model 14?
mattl
I've seen these posted here and a while back someone helped to identify this vac from my childhood memory. Anyway I set a search in eBay for it in the odd chance one would turn up, well one did. I put in what I thought was a reasonable bid and now it's up over $100 and the reserve is still not met. Are these really that rare? This is out of my price range now as I'm not a collector and it was just a "nice to have" item for me.
Here is the link in case anyone here might be interested.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=290239302638&ssPageName=STRK:MEBI:IT&ih=019
Model 14
Started production 12/19/1955
Ended Production 10/2/1956
total sold: 90,689
Compare that to model 12(maroon Lark)
Started production 10/19/1953
Ended production 1/31/1956
total sold: 184,867
Rarer Than You Might Think
In October of 2005, I sold, on eBay, a Hoover Lark Model 12, complete with converter and tool set, extensively restored. I do not wish to unduly influence the current auction for the model 12, so I will refrain from mentioning the final sale price until after the close of the current auction. Let's just say that I was, to say the least, blown away! The opening bid was, if I recall, $49.00.
Here is the description I used:
VINTAGE 1955 HOOVER LARK VACUUM MODEL 12 WITH TOOLS
Thank you for considering a bid on this fifty-year-old example of Hoover’s agile upright vacuum, the “Lark” model 12.
The model 12 replaced the larger model 29 as Hoover’s “popularly priced” upright cleaner in 1953. Not only was it less expensive than the model 63 but it was significantly lighter weight and easier to maneuver and store in small apartments and by owners who might not be able to lift and push a larger machine. It weighs 13 pounds 11 ounces, whereas the full-sized 63 tipped the scales at 18 and a half pounds. The Lark 12 was produced between 1953 and 1956 with serial numbers from 8,570.001 to 8,757,772. This machine has serial number 8,754,956, placing it near the end of the model run, whence I surmise a production date of 1955. The 12 was replaced by the 14, identical in all ways to the 12 except for finish color and possibly the material used for the outer bag.
The Lark 12 is equipped with Hoover’s type-C disposable filter bag concealed within the snazzy, deep red with silver thread and screen printed, fabric outer bag.<p> The Lark 12 and Lark 14 shared the same tool set, the powder blue model 1400 “Cleaning Tools.” One such set is included with this vacuum. It struck me as odd that a red-finished machine like the 12 should be fitted with a set of blue tools, but, advertising art from the period confirms that the combination is true to Hoover history. The tool set comes to you in its original corrugated cardboard storage box. The box itself is in just good condition. There is some evidence of age and wear. The tools set itself is in excellent condition. All components have been disassembled and cleaned. Included within is:
• An “Ultraflex” hose. It is wire reinforced and vinyl covered with aluminum fittings at either end. The tool end of the hose has a built-in curved extension tube with Hoover’s first use of the latch-on-hose connector system, this one all-metal with a vinyl sleeve matching the blue of the hose and tools. The hose stretches from 6 feet to 12 feet in length.
• A 22 inch straight extension tube, again with color-coordinated metal latch.
• An all-purpose dusting and upholstery brush with natural bristles, blue vinyl body and metal collar
• A hard-pressed fiber/cellulose crevice tool with blue finish (there are some scratches on this piece)
• A cast metal hose converter. Refer to the photos to see how it is installed.
The data plate on the underside of the motor reads as follows (excluding the patent information):
The Hoover Cleaner Model 12
10 to 115 Volts DC to 45 Cycles
105 to 120 Volts 46 to 60 Cycles, 245 Watts
The Hoover Cleaner Makes Rugs last Longer.
The Hoover Company, North Canton, Ohio.
I completely disassembled this vacuum cleaner. Every SPEC of dust and dirt was removed from every part, crevice, nook and cranny of the machine AND the bag. The bag, bellows, tube, fan chamber, fan, agitator and agitator housing were thoroughly sanitized. All mechanical and electrical parts were inspected for breakage and or wear and were repaired, lubricated, cleaned or replaced as necessary.
A new belt is installed on the agitator. Incidentally, the agitator has been fitted with new-old-stock, genuine Hoover brushes.
The electrical cord itself has been replaced. The new cord is VERY close to the original in color AND I was able to surgically remove the original “HOOVER” embossed plug and reinstall it on the new cord. The cord now measures 25 feet long.
The painted finishes and vinyl bumper are original and unrestored except for having been cleaned and polished. There is some scratching of the paint as is shown in the photographs. The paint around the grip area of the handle has worn off, exposing the metal underneath, typical of most fifty year old painted metal handles.
This Hoover, may weigh almost 14 pounds, but, like its brethren, it is so well balanced and designed that it seems to float across the carpet with almost no effort, even though it is NOT equipped with a power drive device. Also, and true of all traditional uprights, the handle exerts almost no downward pressure on the user's arm while in operation! Compare this to ANY of the new machines on the market today. The machine is rare indeed that DOESN'T force the user to continually support 8 to 12 pounds of tools, hoses, cyclonic filter systems, cord winders and MOTORS!
I think you will be impressed by how well it cleans with only 245 watts of power. It is hardly silent but earplugs are not needed.
In conclusion this Lark 12 is a prime candidate for a collectors bevy of Hoovers OR to be put into regular, full-time service for cleaning a small house or apartment, reliably and well, for years to come.
Thank you very much for considering this auction.
I am a hobbyist who loves to restore vintage appliances. I am confident that the restored vacuums I offer for sale are in excellent working order and, in the case of this Hoover, may be used for day-to-day cleaning if the purchaser so wishes. Nonetheless, as a hobbyist, I am not in a position to offer any guarantees other than that the machine is as described above. Therefore, please understand that ALL SALES ARE FINAL.
Place cord and cord protector in cord support clip with large end of protector down and rounded side of protector against the handle. Place the large end of protector in lower end of cord support and tighten the clamp nut.
How Rare!!!
Hi Matt, Quite rare I would say, although there is one over here!!! cue said person!!!...did you get to use the vac or as a kid where you frightened of it??
Marty, nice looking vac and the bag is the same material as our 1334 Junior, which is a complete nightmare as you only need to look at it and it snaggs!!!
It seems odd that those where the only only coloured tools that came with it...was the burgundy model out before the blue Lark or at the same time??
Cheers, Mike
lark
Hi Matt
How wonderful! what a lovely machine, tell me does it have a paper bag I would say it hasnt as i think 1334 was the fisrt hoover to have this, also is there a blower facility for the hose? I love the toolset. Dont the hoover tools keep well? They seem to stay like brand new even after 50years, I think I mentioned I sometimes smell the hoses, they still have that newness rubbery smell when stretched.A friend of mine is on her 3rd dyson hose on 2yrold machine!
si
Love, the Lark. I have a model 14, use it from time to time. Its just right for my 2 bed apt. Sure wish I had the toolset!
As it would match the blue and gray color to a tee. If any one knows of a set out there in Vacumland. let me know. If
I could even find the hose and connector ! The vac was a gift
from club Member Don O'conor in Youngstown Ohio. I am still
trying to track a set of sweeping brushes for mine, because I
enjoy using it!
Norm
brush strips
Don Oconor can re fill the old brush strips. just send him the old wore out ones. I just got back a few sets that he redone for me. thay cost 15.00 a set + shipping.
Chirs
Lark 12 Specs
Yes, it uses a type-C, bottom-fill disposable bag inside the cloth outer bag. And, yes, a blower adaptor was available but was "furnished only on special order." Part 47624. The entire bag assembly would be removed and it would mount on the main casting as did the bag ring. A blower adaptor from a Convertible could also be used, mounted onto the fill tube inside the cloth bag. But, when the 12 was first around this part had yet to appear.
'...although there is one over here!!! cue said person..
That'd be me then! It has been lucky enough to have received two visitors last week, ambassadors representing the Kerr and Ellis collections :)
Is there a problem with the bag pulling loose at the bottom on these Larks? It looks in the photo like it's awfully tight, appears to be quite stretched out. That would seem problematic to me.
Hmm...
Maybe in some cases, but the spring which suspends the bag should allow it enough 'give' to stop this happening. More of a problem, I would have thought, would be the thin fabric chafing against the bellows, or snagging on things. It's very similar to our Junior 1334's bag material - although the Junior's is possibly even thinner!
Thanks Chris
I have phoned and left a message, also emailed and no return
call or mail. Maybe I should tell whomever I talk to what I
need. I stated in the email and on the phone that I was from
the vac club. I'll try again.
Norm
Sold $162.50
"vacphone" got it. Is that a VL member? Looked like a nice unit, good shape. It was about $100 more than I bid. No idea it was so rare. Oh well, maybe next time....
Hoover Lark 14
I was told by a vac shop owner that he used to throw them in the dumpster by the dozens (oh the Horror) He said they were an economy model of Hoover. I always wanted one also but now I have four.. One in excellent shape two in fairly good shape and one that needs servicing or new bearings in the motor. I was going to part out that one. But I am going to be selling at least one of them soon when I go through all these doubles and triples of vac models..
