How does one retrofit disposable bags into pre-Tradition Kirbys?
amtraksebo1997
Vacmasterthegreats basement
I can't stand dump-out bags. I think they're a relic of the past that should stay in the past (are you listening, Sanitare/Bissell?). That said, I like certain dump-out bagged Kirbys, mainly the Sanitronics and Classics. However, Because they utilize dump-out bags, that means that I wouldn't want to use them period. You could of course stick a Traditon, Heritage 1,Heritage ii, or Legend ii outer bag with a fill tube on it to solve that problem, but they simply wouldn't match the machine, and that would bug me. So, I'm wondering/hoping there's a way to retrofit a fill-tube (preferably one for an F/Twist bag), and maybe sew a zipper onto the outer bag. Has this ever been successfully done by anybody here?
If
You use a heritage emtor with fill tube this is one way.
You'd have to have a 516-heritage model with 3 ring adaptor for emtor.
You would then buy the new adapter for the heritage as it would take kirby type 2 bags. Then any bag would like have a heritage full length bag with it.
In defense of the dump bags-they are favored for commercial use.The amount of dirt a commercial vacuum picks up in even one shift would fill a large pack of disposable bags.This would get VERY expensive!You can get aftermarket bags that use disposable bags if you should want to use the vacuum at home.
I totally agree about not liking the shake out bags…
That’s one of the main reasons why I hate bagless vacuums; they are a gross mess to empty. I ran into this issue on my Classic III. I wound up buying used on Ebay a “genuine aftermarket” bag made by the Scott Fetzer Co. that takes Eureka F&G bags, as a nest of mice had destroyed the bag and Emtor prior to me taking ownership of the machine. It does look a bit different from the original bag, however. I also recall seeing a youtube video where someone had 3D printed an adaptor from the Emtor of a Dual Sanitronic 80 to a Kirby fill hose. The guy said that he was planning on making more of them to sell, but I don’t think anything ever came of that. Your best bet for maintaining originality would probably be engineering an adaptor and sewing a zipper in an original bag.
Hope this helps,
Thatwasherguy.
Lesinutah
Where could I find myself a "516-heritage model with 3 ring adaptor for emtor" that you speak of. I'm not as knowledgeable on pre-tech drive machines. That being said, what's stopping me from taking that Heritage 1 emptor and putting a Heritage ii or newer fill tube on it?
tolivac
I don't want this to turn into a big war over if they're bad or not like my last thread on the subject, but I simply don't care how much dirt is picked up by a commercial vacuum in a day. I'd rather burn through bags then be content with a poorly filtering setup. I also don't believe that disposable bags fill up super quickly in commercial environments. They may fill up slightly faster than if they were used domestically, but not in a way that Dyson or some other company may lead you to believe. If that actually were the case, I'd just buy a bagless vacuum with sealed HEPA filtration, because at least those have decent filtration, unlike dump-out bagged machines.
Thatwasherguy
I never knew Kirby made outer-bags that took a competitor's disposable bag. That goes without saying that's very strange.
Sewing a zipper on an outer bag doesn't sound that hard, though since I've never sewn anything before, I wouldn't know. Could anybody help explain how to do so?
H2 conversion...
I, too despise dump bags with a passion, and thus have done several Heritage II bag conversions on older Kirbys. The first was a Heritage 1HD, factory equipped with a dump bag. I initially just swapped a complete Heritage II (H2) bag assembly onto it, which worked great but just didn't look right with the gray outer bag and gray plastics. I eventually replaced this with a proper orange outer bag, thanks to a generous fellow Vacuumlander, retaining the H2 mini emtor and fill tube, to give it the proper look. I did this again with a Heritage '84 that had a type 2 bag system because I couldn't get the original emtor and fill tube assembly back on after I laundered the outer bag. I had really wanted to use the type 2 setup on that one because I have a small supply of type 2 bags I wanted to use up. The last one I did was a Classic III, on which I replaced the original red tartan dump bag assembly, which looked like it ought to have come with a bagpipe accessory, with a Legend II bag assembly. This is identical to the H2 setup, except the red and the gray on the bag pattern are reversed from the H2, making red the more dominant color, instead of gray. It looks quite nice with the red Classic III bag topper installed. I had actually considered doing this with the first 1HD I retrofitted, and likely would have done so, had I not been able to source a proper orange bag.
All that said, I suppose, if one had the requisite sewing machine skills (I certainly don't), and one could find some fabric close to the right color, weight, and texture, one could sew a replica bag with a zipper, using an H2 bag as a pattern, and either taking the spring coil from it or sourcing one for an F&G setup, to finish it off at the bottom to make a more original looking filter bag setup.
I agree Rex. I used to clean for a local furniture store and they had two vacuums, one bagged and one bagless. I had to buy and change the bags out quite often on the bagged machine, and I had to clean out the bagless machine often. Both of which became very annoying. So I donated a couple of machines to them, one of which had a shakeout bag. Wasn't the best but I did liked it more as I didn't had to empty it out as often. I have some shakeout machines in my collection and none of which I plan on converting over to use disposable bags. I also do have a Kirby 512 that unfortunately had it's original outer bag swapped with the one that can take a Eureka F&G or a Royal type A bag, I hate it. If I could, I'd gladly swap the outer bag to a shakeout but I also have to find an emptor for it as well so that's one of the reasons why I hadn't bothered to restore it.
Ok
If you use a bag from 519 or older kirby. You unlatch the top of the bag and it would slide over the heritage setup.
I didn't see you didn't want to use a heritage bag.
You could get a seamstress to install a zipper on the shakeout bag.
Anyways returning to the topic
I've seen one person do this on his Classic Omega bag. I originally thought about doing the same thing on mine but then later decided against it. But it was a cool setup nonetheless and think that this can be done easily with just about any shakeout model.
PanasonicVac
Why is it that when people are recommending vacuums for homes here, they recommend bagged machines, but for commercial use, dump-out bagged machines are recommended here, and the argument of them filling up quickly and bags being expensive is used?? (not saying everyone does this, though). Once again, I do not believe that they fill up at such extreme rates to warrant the use of dump-out bags. You're sacrificing air quality for the money spent on a pack of bags. The only application I can see them being okay for is ones where you're picking up large, clean debris, and not dirt and dust. For example, they may be suitable for carpet installers to vacuum brand new carpet to get rid of loose fibers, and very little if any dust. Anything else, and you wouldn't want to use them.
Lesinutah
As I've said, I don't want to just use a Heritage ii bag setup on anything other than a Heritage ii. That DS50 doesn't look right with it on.
The one on that Classic Omega shown in that video is the exact setup I'm talking about. It has its original bag, but has an added zipper and a retrofitted fill-tube so it can take HEPA bags. I don't see how hard it could be to replicate that. I suppose if I were to do it, I'd start by experimenting on my Dual Sanitronic 50 (it already has a mis-matched bag to begin with, so I want to replace it anyway), then get a machine like a Classic III or 1CR and do the same thing.
Commercial buildings have a filtration code unlike residential homes, they shouldn't be a problem for commercial use.
Commercial buildings track in more fine dust that'd easily plug up the pores on a disposable bag, definetly a problem for me with going through a ton of bags and run out of stock as that's happened to me before.
You ought to reread one of your old threads from Bill (vaclab) who has scientific evidence that shakeout bags aren't as bad as you think. In fact that bagless machine I mentioned before had WAY worse filtration than the shakeout machine. That picture you shared I remember came from Vacuum Wars who's misleading with his tests and I think bias, I'd much rather listen to Bill than Vacuum Wars. https://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44722_37
PanasonicVac
First of all, you're using my old thread from 2 years ago about why I despise dump-out bags. That thing was hot trash, and I don't agree with a lot of things I said in it.
Secondly, maybe VacuumWars isn't the most accurate or scientific vacuum reviewer on Youtube, but the simple fog test shows that it doesn't filter well. How and why you'd fabricate that result is beyond me. Heck, my school had the EXACT SAME MACHINES as Vaclabs, and I can recall them having copious amounts of caked dust all over them. I've seen other Sanitares in similar states. Now, some of it might just be because of kicked up dust from the roller that clinged to the machine, but I think most of it is from the awful filtering of the machine.
Thirdly, certain businesses accumulate a lot of fine dust in their facilities, and instead of the vacuum filtering it out of its exhaust air, it's just blowing it back into the air you breathe. Now, maybe in some places the HVAC is pretty good about filtering it out of the air, but am I gonna rely solely on it to do so? Absolutely not. For all I know, that HVAC system is as nasty and under maintained as the Sanitare that I'm hypothetically using.
