Hoovers which take Type A bags
broomvac
N/A
Something unique about the Hoover Type A bag is that it spans several vastly different vacuums. Convertibles, Guardsmans, Conquests, Concepts, Powermax, Elites, Legaies, Runabouts, etc. The list goes on.
Just for fun: Which vacuums do you have that take Type A bags? What is your favorite Hoover which uses them?
I currently have 3 vacuums which require type A bags. My U3317 Hoover Concept I, my Hoover C1403, and my Kenmore High Performance "Kenvertible." I use the synthetic HEPA ones.
My ultimate favorite, though, is not one I own. It's the Hoover Legacy, soft bagged, in the charcoal color.
On a side note, aren't Type Y and Type Z bags virtually the same as Type A bags, just shorter? How do they differ?
Y/Z bags use the same collar, they are just a few inches shorter. An A will work in place for a Y/Z but a Y/Z will not work on place of an A. The weight of the bag will tear the collar.
Don't forget the Hoover B style. It also is basically an A bag used on the Oreck/Tacony knock off called the clean and light and I believe the Sovereign as well.
Here's a fun thought. What other band of vacuums can you think of that will use Hoover A bags.
Kenmore power center, royal metal upright, Singer/Bissell uprights of the 90's and more.
I have Several Convertible, Concept, Elite, powermax, and decade machines as well as Innovation, Sovereign, and runabout that take A bags.
Phillip, the Hoover B bag is the same basic size the Hoover Y bag is, BUT the collar is a little bit smaller than the Hoover A/Y/Z collar. if you try to put a Hoover A bag on a vacuum that uses the Hoover B, it will not stay on properly & cause a mess.
Hoover UK's 'H4' bags are suitable for the 'Turbopower 1', 'Turbomaster' and 'Turbolite' which was the imported USA 'Elite' in disguise.
Thus I would think that the USA bags suitable for 'Elite' would also fit the 'Sovereign' and the 'Innovation'.
One Design difference between the Hoover A&Z and the Y is that the wise for a bypass machine and typically two or three layers. The A and Z or for direct air machines.
I do use a HEPA Y bag on my concept one you just need to be careful that you don't feel it too much being that it's a smaller bag.
A good gym to find is that there were Hoover HEPA A bags made by Tacony in the mid-2000s
Hoover Company Single-Letter Vacuum Cleaner Bags Table 1950-
I found no quick reference online, so I made this. Corrections/additions invited.
HEPA Y Bags for Hoover Concept
When I bought my Concept Two U3309 from the thrift shop, it came with a paper Y bag installed and a pack of three empty Y bags. They seemed to me to be the wrong bags because, while the collar fit, the paper bags were shorter than the zippered fabric. So I bought and now use Type A bags for it.
Since I already had some type Y bags, I found a Hoover Windtunnel U6485-900 in another thrift shop to use them with.
Next trip back to the first shop, I found and bought a pack of Hoover type Y HEPA bags and was stunned to see that the package says it's for Concept One and Concept Two. Did Hoover not make a HEPA A, and instead label their HEPA Y for use in a taller environment?
The Y bag is much shorter than the A, so the Y hangs suspended by its collar in a Concept instead of resting on its bottom.
Straight from Hoover ...
p.s., Yes, there is a green paper Y bag that I stuffed in with the white HEPA Y bags after I opened the package. Now all my Y bags are stored together.
