Hoover Turbopower U2334 Rebuild
beko1987
Stokenchurch, United Kingdom
November 1986
From Hoover Turbopower U2334
I'm sure it will look familiar to someone on here! Looks to be an early model too at 480!
All bar one screw came out of the handle cover, it was so rusty I tried for half an hour to tease it out using avariety of methods. Sadly none of those worked so I carefully snapped the housing around the screw. This should glue together and be pretty invisible, and I have another screw
It came out with some pliers after this
Handle Orf
Its been so long since I've done a hard bag TP I forgot it did this
Thought how the hell is that going to come out of there etc
Emptied
Gulp, Autoflex next
Sorry, refrence shot!
Had to chop this connector off
And finally the beast was free!
Time for the botom end
Yummy
Pop the Bonnet
Removed the 2 clamps and finally stopped it tipping backwards and wiping stuff off my shelf
I've never seen a motor setup like this. The screws were flathead rather than philips too I noticed
Marked the location of the wires
Blue is on the opposite corner...
The fan was in fine fettle
De fluffed the other fan, and soaked the bearing in plusgas which has it spinning much better now!
Carbons about halfway through life, so plenty left for the future!
Autoflex again now, and I consulted the 1990 book of Hoover
All the tension went from the cassette, but thats fine because I can re-tension it when re-assembling (much easier when its back in the cover)
I gingerly undid the spring cover, sprayed plusgas around and put it back...
And gave the whole thing a clean up
Picked the activator clean too
It's soft as anything though so will wash it and try it, but I have a few better ones that will probably go on eventually. The green end ones can barely hold themselved up
Had to clamp the bearings in the vice and turn the shaft with grips to get a bearing off
And thats it for now. My U1222 is drying, so I'll wash this one Sunday hopefully!
