twocvbloke
- Joined
- Dec 27, 2010
- Messages
- 2,148
Well, I doubt that Hover will have fitted the plug, as back in those days, appliances generally came without a plug, and either the retail shop it was bought from, or the customer themselves fit a plug, and some people didn't (and still don't) quite understand the meaning of fuse ratings...
A 13 Amp fuse is for devices that use up to 3 Kilowatts, and I don't think your 600 Watt Ranger uses that much power, if your motor shorted out, then your cable will heat up pretty fast, catch fire, burn you, your carpet, the vac itself and maybe even your entire house before the fuse blew, if it blew at all, this is the reason why you NEED to fit a 3 Amp fuse, they're designed with different ratings for a damned good reason, regardless of whether some low-IQ person in the 70's fitted it, it's for your safety, if you don't, well, I hope you have Home and Life insurance........
Just because a plug says it can have a 13 Amp fuse fitted doesn't mean it HAS to have one fitted, be smart and fit a 3 Amp Fuse...
