Hi!
I posted here a while back about help with brushrolls and I received some great advice which absolutely helped me in my restoration process so far. I'm hoping you guys can help me with another issue.
I've been restoring this hoover model 300 for the past year or so now. However now that im close to finishing , Im realizing that I may have made a rookie mistake when I bought it.
One of the fan blades on the motor has a decent size chunk missing from it. see attached picture.
I have just turned it on and the motor is extremely loud.
The only other thing i can think of that could cause it is thd fact that i had just replaced the carbon brushes. The motor was only buzzing before.
Now, when I start it up it becomes louder and louder almost to the sound of an actual lawn mower. I have to shut it off pretty fast; less then 5 seconds after. I start the power. I don't want to burn the motor off or destroy the vacuum in any way.
Is there any way I can fix the blades; or do I need to replace it with another motor or blade? Is that even the issue on why it's so loud?
There is an ad on Craigslist for another hoover model 300 one but I really don't want to spend $100 for another full model and travel a 7 hour round trip to pick it up. However I will if it is necessary.
What do you think would be the best option? I've spent a lot of time fixing this guy up and really would like to get it up and running. Any help would be appreciated.
Thank you,
Sean
Thank you,
Sean
