Well, ummmmmmmmm ? ? ?
"@hoovercelebrity: If I were to use a lathe, as MPN suggested, I would imagine I could easily use commutator stones, am I wrong?"
NO! use the lathe's cutting tool bit, because you want to remove as little material as possible to achieve "Concentricity". Using a hand-held stone will only follow the "Eccentricity" of the OUT OF ROUND commutator MAKING MATTERS WORSE!
1.Turn the commutator on a lathe until concentric. 2.Finish dress with a fine Scotch-Bright Pad.
