Hoover Constellation wiring...
fantomfan57
Austin Texas
Hi folks, hope you are still safe.
Does anyone have a wiring diagram for a Constellation. I worked on at least 4 machines since I dismantled it and for some odd reason I can not figure out the wiring.
I have a wire each coming from what looks like the area surrounding the coil, but there is a place for wires to attach at each brush housing. Of course there is a on off switch with two spots on it.
I must have gotten things mixed up and should have taken pictures.
HELP!
Always remember a simple formula that helps:
There are two leads from the cord, two from the switch, and two from the motor.
Join one cord lead and one switch lead.
Join one motor lead and one cord lead.
Join one switch lead to one switch lead.
If there's a power nozzle receptacle (the constellation doesn't have one):
Join the two power nozzle receptacle leads one each to the two motor leads, then proceed with the wiring as stated above.
