Hoover 28 Brush Bar
coppercitymt
I need to know were I can get my brush bar fixed, the brush bar has removable brushes in little metal trays like. Were can I find them?
Also were do I find a replacement light bulb?
Thanks,
The lightbulbs
can be found at Lowe's. They are in a little drawer.
As far as the brushes, there is a place (archives here) where you can get them re-bristled. New ones are not readily available. Someone else in here may be able to shed more light on that. Best of luck.
If you could give me a part number or something that would be very helpful. The closed lowes is about 100 miles away.
Also if anyone can come forward with a name of anyone who could rebrush my bar I will gladly pay to have it done!
parts
any older hardware store would have a light bulb. I can help you with brush strips and any other part for your model 28 Hoover. be sure to use the right Hoover belt part # 44783
hope this helps. my contact info is in my profile.
Chris
Photos
Thanks for the feeback so far, here are some photo's. I am going to repaint the motor cover. I have not desided if I want to paint the base, a almost 70 year old vac should have some battle scars.
If...
You are going to Young's for a brush re-bristle, they most likely will have the bulb. They are a very old fashioned vacuum store. But as it is pointed out, any good hardware store should have the 15w bayonet-base bulb. The bulb may be 12v and powered from the motor's field.
Found Parts
With the help of two fourm members, I have found so far what I am looking for, I found the light bulb at ACE "Westinghouse Part #03722" 15W 120v. I will keep you updated as the resto progress.
Eric,
Best of luck to you on your restoration! The original bag you have on it appears to be in excellent shape, and that's a great start--they are hard to find! And seeing it has the metal hood makes it somewhat rare if I'm not mistaken. There weren't nearly as many of those as there were with the bakelite hood. Congrats on a great find. The 28 is one of my favorite Hoovers, and a machine I believe every collector should have.
Thanks, yes the bag is in perfect shape, It has been fershly washed in that photo! Yes the hood is soild metal, aluminum I belive. I will surely post a photo up here when I get the hoold painted.
Thanks for the comments! Toke me a few hours with waiting for drying time. I got the parts from Chris Sezwejk brushs and belts and it cleans as good as new.
