Hepa bags. A gimmick?
As much as I love HEPA
bags, I do sometimes wonder if it's the rubber area seal around the collar of the bag and how tight of a fit that goes onto the vacuum that's most important. You can have a HEPA bag or a paper bag and they can both leak if that's not a good seal connecting to the bag. I had this problem with Kenmore canisters. Always always dust in the bag chamber. My Epic 6500, even using the 4 play paper bags, no dust in the chamber...those aren't HEPA bags......but I do notice airflow drops off rather quickly on those. With HEPA bags, the airflow stays pretty decent throughout.......which you would think would be the OPPOSITE since HEPA bags are thicker.
Keeping a super clean home might not be the best for people and their immune systems, but it's better for things like your refrigerator, HVAC, etc.
Hepa
I've come to believe that HEPA bags filter really well. I noticed my compact with HEPA gets very fine dust. The vacuum performance is about the same. If you have allergies I'd only use HEPA(I don't have allergies). I still tend to use hepa. Older eureka/hoover/sanitairre f&g I use oem or high filtration. The royal I use type a royal bags they seem to work better than other bags. Type b royal Im not a big fan of I use other HEPA bags.
HEPA Cloth bags are definitely NOT a gimmick. They do work better than paper bags. I find I don't sneeze as much, don't see as much dust on furniture & don't have to vacuum the pre-filter on my Honeywell air purifier as much if I use a HEPA Cloth bag in a vacuum that doesn't have a HEPA exhaust filter, like my Kenmore EVPC canister or Royal Metal & Kirby uprights. In fact, HEPA Cloth bags, even generic ones, work so good that whenever I get asked for a vacuum recommendation for a allergy sufferer, I always say first that if there is a HEPA Cloth bag available for the vacuum to try it first before replacing the vacuum. While it doesn't capture the carbon dust on the exhaust, the HEPA Cloth bags will capture the majority of the fine dust that triggers allergies.
However, unlike some other members here, I have not found them to maintain the vacuum's suction or airflow better than paper micro-filtration bags. The ONLY bag I have found to be the exception to the rule is the Miele AirClean & Miele HyClean 9 layer HEPA Cloth bags - those bags are amazing in that you can stuff them full of dirt till 3/4 full & only then do you see suction & airflow drop off slightly, & no dust in the bag chamber either. Any other vacuum though, like my Kirby or Royal Metal uprights, use the paper micro-filtration bags in them & they maintain airflow just as well.
Kenny & MadMan - I disagree with you guys on the importance of keeping a sterile environment. Yes, a lot of people born years ago didn't have a allergic reaction if you vacuumed with a vacuum with no filtration that let off lots of dust. However, there are LOTS of kids being born these days that are allergic the moment they are born. Furthermore, what we know today is the dust in carpets is not healthy! And that's not just my opinion, that is a proven fact! There's a reason why leading environmental & government agencies say that indoor air quality in today's tightly sealed homes is a problem. Do you guys have ANY IDEA of the chemicals & processes used to manufacture carpeting? I bet you didn't know that FORMALDEHYDE, the same chemical used to preserve human corpses before burial, is used in the carpet manufacturing process, & remains in it & leaches into the indoor air after it is installed. Plus let's not forget the chemicals that leach out of plastics, finishes & painted surfaces. Your average vacuum is using this air to pick up dirt & dust, & then spreading all that dust & chemicals all over the house!
I see nothing wrong with letting kids be kids & letting them go outside & play in the dirt - but they shouldn't be breathing dusty air from a vacuum & being exposed to all those allergens. You should at the very least be using a vacuum with a HEPA Cloth bag, or a sealed HEPA filter on the exhaust, & if it's bagless empty the bin outside. I also think it's a good idea to have a HEPA air purifier running too. Yes, kids should be kids & you can't protect them from everything, but I see nothing wrong with taking a few preventative measures to reduce the chances of them developing allergies later on.
Mylesrom - I would be careful buying those Kenmore bags by Clean Fairy. Just because you don't see dust in the bag chamber does NOT mean they're not releasing dust into the air. Bill, Vaclab on YouTube, just did a test where he compared a Kirby HEPA Cloth charcoal lined bag with the Clean Fairy Kirby HEPA Cloth charcoal lined bag. His tests showed the Clean Fairy brand released a LOT more dust into the air than the genuine Kirby bag did. Sure, the performance of the Clean Fairy bag would have been OK if it had been used in a vacuum with a HEPA filter on the exhaust, but not on a direct air vacuum where the bag is the only filter. I also personally have bought a couple packs of the Clean Fairy Miele FJM bags, & I wasn't impressed with either the quality of the HEPA Cloth material used or the bag collar. I definitely won't be buying from them again.
Mark - Yes, you're right, the seal the bag collar makes with the vacuum when installing the bag is important. A HEPA Cloth bag will do no good if dust & dirt can leak around it inside the vacuum. The Kenmore canisters are a good example of a less than ideal bag collar & bag holder design. The reason why you constantly saw dust buildup in your Kenmore canisters using HEPA Cloth bags was because the bag collar would slide up slightly in the bag holder, & some dust & dirt wouldn't make it into the bag to be captured & filtered. I personally make it a point to tape the bag collar to the bag holder on my Kenmore canisters to decrease the chances of that happening.
Hmm
The riccar brand HEPA bags for rsl4 doesn't reduce suction, Kirby newest HEPA loses very small amounts. I don't have a Miele and seen there bags they look the most convenient and consumer friendly bags out right now. My compact doesn't lose air flow with HEPA bag. There are a few but it's alot healthier on vacuum with them. Les
We are all different
with different levels of allergies. I can't make a generalization based on everyone. I don't think anybody can. I was just reading an article on Formaldehyde one of the remedies was to open a window. Which defeats the whole purpose of having a sterilized home in the first place. The article also said the levels of Formaldehyde are highest when products are new. Maybe some of these allergic kids are allergic because their environment is too sterile. I'm a not an allergist. I'm just guessing.
If a person is reasonably healthy the body's immune system should be healthy enough to fight off colds, etc. Go outside for a walk and breathe in some fresh air. lol!
My cirrus upright
vacuum........I filled that bag up and if there was a loss of suction, it was VERY little. Now, on the Kenmore canister, I noticed a loss of suction as the bag filled. My Kenmore blue canister where the PN died, I use the vacuum as suction only for the garage, and I do TAPE the bag so that it doesn't slide off.....but I still feel like even with that, it doesn't make a tight enough seal like, say, an Electrolux canister. I get better results with the Electrolux paper bags keeping dust out of the bag chamber than I do the Hepa bags in the Kenmore canisters. That bag collar design has GOT TO GO.
KirbyLux77
I never said that the Clean Fairy or other generic hepa type bags were equal to Miele or Kirby original hepa bags...they are not. The question was are they a gimmick and my response was they are better than the paper bags, which they are. The original Kenmore paperbags always leak into the chamber. The Kenmore Progressive doesn't have a perfect seal at the neck connection anyways, so I would not spend 5 or 6 dollars a bag on them and I did have a couple of SVC hepa bags that came with the canister when I purchase it for 10 dollars. They were no better quality than the clean fairy bags. If I had a Kirby or Miele I would only use their original hepa bags... I wouldn't chance a Miele on generic hepa bags.
Vac Lab Videos
I watched his videos... Kirby Orignal Paper = 11,559. Clean Fairy hepa type, 1400 at 0.3. So even generic hepa type are better than paper. Though not as good as Original Kirby or Miele bags.
Miele GN bags
Miele GN bags are fantastic. They are very thick and airflow difference between empty and full bag is very small. Only 10 cfm loss with full bag.
Kirbylux77
on the point of Clean Fairy hepa bags.....even though the Kirby HEPA bags were much better in his testing, even HE stated that the CF bags were just fine ( he gave numbers to compare by)....the '1400' number for emissions is very small....nothing like paper bags. Just for clarity :-). I bought them and told someone else about them and then he sent Bill/Vaclab to test....and I have noticed no difference from a 'users' perspective compared to the genuine HEPA bags.
I did know about the formaldehyde issue in carpets....I worked in a air quality control for a brief time. SO I use ozone/neg ion generating machines to neutralize the out gassing of a new carpet/drapes/cloth furniture(less than 50ppm). Good points though you gave on that and indoor air quality!
Kelton - First of all, thanks for the compliment. When I found out a few years ago I have allergies, I decided to become educated on indoor air quality so that I could reduce my symptoms. As a result, I am much more careful about cleaning practices, the quality of vacuum I use to clean my home, & I constantly have a Honeywell HEPA air purifier running 24/7 in my living room. I am currently using a 2007 Miele Callisto & a 2014 Simplicity Gusto.6, both with HEPA filters & HEPA Cloth bags, to clean my home, & both are immaculately clean & in pristine condition.
As for the Clean Fairy Kirby HEPA Cloth bags, I would agree with you - the result isn't "that bad". But, compared to the genuine Kirby HEPA Cloth bags, in my opinion they ARE bad....90 particles for the genuine Kirby HEPA Cloth bag vs 1400 particles for the Clean Fairy Kirby HEPA Cloth bag is a pretty big difference! That to me is unacceptable. If it had been under 500 particles for the Clean Fairy Kirby bag, that would be acceptable & make them a good alternative Kirby HEPA Cloth bag. If this bag was being used in a clean air upright with a sealed HEPA filter system, like a Miele Dynamic U1, Kenmore Elite or the Cirrus uprights, you could sacrifice the quality of the bag a little to save money buying generic bags, but when you consider this is the ONLY FILTER in a direct air upright vacuum, that isn't acceptable. And especially when there are plenty of other generic Kirby HEPA Cloth bags on the market by Envirocare, Crucial Vacuum, Zvac & VEVA that are widely available. If it's acceptable to you & Bill, more power to you & you can choose to use what you want. My personal preference though would to be use a better generic brand with better particle emissions, or just buy the genuine Kirby bags & spend slightly more for better air quality. I hope that one day Bill can get his hands on the normal Clean Fairy Kirby HEPA Cloth bags that are not infused with charcoal....I have to wonder if it's the charcoal layer that could partly explain their poor performance compared to the genuine Kirby HEPA Cloth bag. I appreciate your points though & contributing to the conversation here.
Mylesrom - You're right, NOWHERE did I say in my post that you said the quality of the Clean Fairy bags was equal to the genuine Kirby or Miele bags. All that I am saying is, based on Bill's tests of the Clean Fairy Kirby HEPA Cloth bag & my own experience with the Clean Fairy Miele FJM HEPA Cloth bag, I personally don't recommend the brand & will not use them again & I would suggest you try another brand. Based on what Bill experienced in his tests, & my own experience, it is highly likely those Clean Fairy bags are letting a LOT more particle emissions you cannot see than you think, even compared to the SVB HEPA Cloth bags you used previously. Considering your Kenmore canister either has no exhaust filter or has a HEPA filter in a unsealed system that can leak dust around the HEPA filter, that makes the quality of the bag used even more important. Even Kenmore noted in the certifications included with their vacuums that the particle emissions claims they made were based on using the vacuum with BOTH a HEPA Cloth bag & HEPA filter, because they knew their vacuums were unsealed HEPA filter systems. The ONLY VACUUMS they have ever produced that had a sealed HEPA filter system were the Kenmore Elite bagged canisters & uprights, the Crossover bagless uprights & some of their vacuums that were produced for them by Electrolux AB & were rebadged Eureka vacuums. And yes, you are correct about the seal on the bag holder of the Kenmore canister vacuums not having a perfect seal with the bag, but that's the reason you would tape the bag collar to the bag holder, so you maximize the seal the bag collar makes to the bag holder & the HEPA Cloth material has the best chance of capturing the fine dust & doing it's job of filtering the air. By the way, I have actually used the SVB brand Kenmore HEPA Cloth bags your vacuum came with, & actually found them to be pretty good for a generic bag. That is one generic brand I do recommend.
As for your statement that you would only use a Miele with their genuine bags & wouldn't chance using generic bags, I have used the generic bags with very few problems. They don't leak lots of particle emissions & cause problems with the motor like some people here claim they do. Plus, even though their filtration is obviously not as good as the genuine Miele bags, that is irrelevant since the Miele canisters are a sealed HEPA filter system vacuum. As long as the bag isn't leaking lots of dust into the bag chamber, it's perfectly fine to use generic bags because the HEPA filter on the exhaust will capture any particle emissions that escape the bag.
My experience with the generic bags has been the problems are mostly with the bag collar itself & it's design & quality, not with the quality of the bag material itself. If you read Amazon reviews on the generic bags, you can also draw the same conclusion. The generic bags that have the AirClean style collar used the first version of that collar that Miele only used the first couple years the bag has been made. The problem Miele had with the first version of the AirClean collar, & why it was changed, was that the bag installed properly in the holder & worked fine when first installed, BUT if you open the bag door to check on the bag, the bag collar becomes unclipped from the bag holder & slides up slightly in the bag holder. The consumer then closes the bag door without noticing this, the bag door tube doesn't penetrate the bag collar fully, & some of the dust & dirt goes around the collar & into the bag chamber. Even a fellow Vacuumland member who is a Miele dealer, Piano_God, noted in one of his posts that this was a issue with the first generation Miele AirClean / Miele HyClean bags & to be sure to push the bag back fully into the bag collar & make sure it clicks into place before closing the bag door. Since the generic bags up until recently used this first generation AirClean style bag collar, that is why consumers were seeing problems with dust leakage & didn't realize if they were more careful to make sure the bag was installed correctly before closing the bag door, they would have had no issues with dirt & dust escaping & the bag would work just fine for them. However, this problem is slowly starting to go away, since there are some brands of generic bags using the AirClean style collar that DO NOT unclip from the bag holder when you open the bag door, thereby lessening the chance of consumer error. I have also seen personally on some generic bags with the AirClean style collar that the silicone seal can detach from the collar, however you can always just change the bag if the seal does detach & it seems the quality of the silicone & the method in which it is attached to the bag collar has improved over the years, the recent generic bags I have ordered have not had this issue. The only other issue the generic bags have is they do not allow the vacuum to maintain airflow as well as the genuine Miele AirClean / Miele HyClean bag - the walls of the bag clog with fine dust & dirt & restrict airflow. However, that problem is easily solved if you take the bag out after each vacuuming session, take it outside, give it a good vigorous shake, & then reinstall into the vacuum. Doing that loosens the dust & dirt from the walls of the bag & restores airflow.
As long as you only buy generic bags that have the AirClean or IntensiveClean style collar & you make sure the bag is fully inserted into the bag holder & clipped into place, you will have no problem with bag leakage. I would strongly suggest avoiding bags with cardboard collars though - the collar can bend & warp, & not allow the bag door tube to insert fully into the bag collar, which can cause dirt & dust leakage. Even Tom Gasko, Dysonman1, has said he uses generic bags in his Miele canisters, in particular the 3M Filtrete bags with the IntensiveClean style collar, & he finds they work just fine & don't leak dust. Take a look at the bag chamber of my Miele Callisto....do you see any dust leakage from this generic bag?
Kenny - I totally agree with you. I don't think you can make a generalization that everyone's allergies are the same. There are people who's allergies are mild, & those that their allergies are severe. My only point is, as I said in my post, is it seems more kids these days are being born with allergies right from the moment they are born. And of course, we have no idea of what causes a child to develop allergies to certain chemicals, foods, grasses & other things in their environment. My whole philosophy when it comes to my health is that saying "A ounce of prevention is worth a pound of cure", meaning that if I can prevent sickness, disease or illness from happening in the first place by taking the best care of my body, eating right & exercising & taking the right supplements, I do it. So, since we all know indoor air quality is a concern due to dust & dirt in carpeting & various chemicals in the air from the products we use in our homes, I wouldn't want my kids if I had any exposed to dusty, dirty air from a vacuum & I would want a air purifier running at least in the family / living room of the home. I think it would be a good idea to take the preventative measure of using a vacuum with HEPA Cloth bags, a sealed HEPA filter system, or both, & if I was using a bagless vacuum to empty it outside. Having said that, I don't want my kids exposed to a "sterile" environment - I think it would be healthy for them to be exposed to allergens outdoors while playing & let them be exposed to "healthy allergens" in fresh, clean air, not toxic ones inside your home. Kids will be kids - let them go outside, get dirty, exposed to dirt, dust & allergens, let them get healthy exercise in, let them be exposed to allergens that way. I would just rather practice caution in the home in case they do develop allergies to some of the toxic chemicals in the air in our homes.
It appears that many people forget
when discussing particle emissions is their own indoor air quality.
Example: Person "A" demands a fully sealed H13 level system and their typical baseline air quality is 100,000 0.3um. Won't really have any appreciable effect, right?
Example: Person "B" has an average home 0.3um of 1,000 or less, then I'd say nothing less than full H11 would be appropriate.
In my home, using "el cheapo" $2.50 MERV 7 HVAC filters, I usually sit around 10,000 0.3um; however, when my HVAC runs continually (peak hot/cold weather), I can see a home average as low as 4,000 0.3um.
Clean Fairy bags may be just fine for the average home and I'd bet most people wouldn't notice the difference.
As for the charcoal CF having some appreciable negative effect, I would venture to guess that since the Kirby charcoal HEPA and black HEPA bags both tested great (both under 100), the CF non-charcoal bag would also be similar.
Hope this puts things into perspective,
Bill
I'm glad Bill brought this up . . .
I was just about to point out exactly what Bill mentioned. All of this speculating on the possible inferiority of "generic" bags means nothing unless you know the baseline particle measurement for your home. If you haven't measured it, then you're just guessing.
For the record, I'm the guy who sent Bill those Clean Fairy charcoal bags after Kelton sent me a link on Amazon. They look exactly the same, so I thought there could be a chance they were made in the same Chinese factory, which would make the Clean Fairy bag a real bargain. As Bill discovered, they look the same, but the Clean Fairy bag has fewer cloth layers, so this probably explains the higher particle reading (and lower cost). Bill and I spoke about this at length and the takeaway was that the Clean Fairy bag is probably more than good enough unless you need to live in a highly filtered environment AND you have real measurements that confirm you have achieved this with your baseline air quality.
Anecdotally, I've been using the Clean Fairy charcoal bag for a few weeks now and I can't seem to tell any difference. I do not suffer from allergies, so I'm not as sensitive to this issue. However, I have a dog and I find the smell from non-charcoal bags to be disgusting. Even the Simplicity HEPA bags I bought from Tom at the (former) Tacony museum for my Ultra Premium started to smell after just a couple of uses. I have yet to find a non-charcoal bag, regardless of filtration, that doesn't smell awful after a few uses. So, as a pet owner, I'm on the charcoal bandwagon all the way. I haven't tried using granulated charcoal in a non-charcoal HEPA bag yet to determine if it offers better or worse "odor" performance. But, that is more of a hassle than just buying charcoal-infused bags. I suppose this could be yet another performance factor Bill could measure. Does someone make a "smell-o-meter" that could provide some insight?
Both the Kirby and Clean Fairy charcoal bags seem to offer similar performance. Maybe the Kirby bag won't smell quite as bad once it gets full. Maybe not. Until then, they seem to work just fine.
Adding charcoal
granules to a non-charcoal HEPA bag definitely works! This is what I do in my Cirrus upright and I was able to go 5 months without changing the bag. Had it not been for the charcoal, NO way would I have been able to go that long. A long time ago, I bought a big container of fish aquarium charcoal and I've hardly put a dent in the big container. But I don't think charcoal bags exist for the Cirrus upright?
Hmm
Charcoal is Overkill in my opinion.
Veva makes a better HEPA bag than Kirby. The hepa bags for TriStar isn't brand name.
People like charcoal bags it's a personal preference.
Everyone is entitled to opinion and preference for things. Some people are blinded by own convictions and proving their points. The person is so focused on proving point and being right they are oblivious to doing do changes how people perceive them.
If people are entitled to opinions they're also entitled to false beliefs.
Continually posting how correct you are you lose respect. Nobody is going to read 7 posts with half hour worth of videos. Nobody cares to listen to how someone is right.
It shows they are self absorbed and extremely insecure.
The continuance is not needed. It's sad to see going to the extreme it seems there Almost mad.
I wish people well but delusional self absorbed selfish people only concern about themselves and their correctness really need to step back and enjoy life get over insecurities and live.
You can come back I don't care. It's only my opinion and that is my right. I'm comfortable in my skin. I don't need reassurance from anyone.
Cheers carry on this wonderful thread.
Hey Les, I do believe in the Kirby Charcoal Odor control bags. Our Golden fur in our old Hoover Platinum is what led me to this site and eventually to a Kirby with Charcoal bags. Before with our Hoover I literally needed to open windows when we’d vacuum. We brushed our dog regularly and she didn’t really stink up our home. Now with the charcoal bags I can go about a month on a bag before I’m smelling dog. Like you say though, to each their own. Do what you like and what works for you.
Kirby bb
Thank you for your suggestion. I may try a charcoal bag. The explanation makes sense.
Kirbybb
I just had a thought. I read your post where you said you got a month on a bag before smelling dog? I'm assuming that's when u change the bag? If not, I wonder if you would try to suck up a tablespoon or so of charcoal granules and I'll bet a day later your bag will smell new again? What happens with my upright is after a couple of weeks.....I will start smelling a slight stale smell, I suck up a little charcoal, that lasts 2 to 3 weeks or more before I started slightly smelling anything, I suck up a little more......rinse repeat. It's like the next day after the charcoal has been sucked up, zero smell. I think the dirt eventually covers it up.
Thanks for that tip, I’d love to actually fill one of these bags up! I’ll look for some charcoal tablets and try it out.
MArk40511
I think adding the charcoal granules is a super idea if one has animals and the bag begins to smell way before it’s close to full.!
