HELP PLEASE !
kirbyduh
Kentucky
i am restoring my older kirby ive ran into a snag tho the three screws that hold the fan case/ chamber together are STUCK ive even tried using a drill to get them out. Any suggestions on how to get em out
Hmmm?
Maybe we should use a anti seize compound when installing screws into aluminum housings esp when we do a nice rebuild.
just a thought.
I've been checking that store quite a while
will have to pick up a few things
Might be hard!!
It might be hard to do if you have already drilled the heads off to the screws.
Drilling them should normally be a last resort always use the impact driver first with some kind od releasing agent like WD40 etc.
Good luck anyway!!
JB
Yeah, stripping screw heads by digging at them in futility with a screwdriver is not the way to go. Instead, insert the screwdriver tip into the screw head then beat the crap out of the screwdriver with a hammer while putting =slight= counter-clockwise pressure on the screw. Works most of the time (unless you've already ruined the screw head) and is a great way to work off a little pent-up aggression!
n.b., dribbling a couple drops of Liquid Wrench or similar down over the screw before the Beating Treatment and letting it sit until it drains down inside will help.
