Help please - Hoover Turbopower 1000 bit the dust...
jmurray01
Scotland
I decided to use the 1994 Hoover Turbopower 1000 today as it had been sitting for a couple of weeks. I did all the upstairs carpets which took about 15 minutes and it worked perfectly, adjusting up and down on Autosense as required, no problems.
I shut it off, unplugged it and went downstairs then plugged it in and proceeded to vacuum the carpet in the hall way. Again, no issues.
Once I'd done that, I put it in the upright position (still running on low Autosense), moved the height adjustment to Shag/Tools, pulled the hose out and attached the extension tubes then all of a sudden the pitch changed from the quiet smooth hum to a really dull noise and it sounded like the motor had slowed down to about half the speed it was running at and a smell of burnt rubber was apparent. I immediately thought I'd caught a bit of thread in the brush roll and it wasn't spinning so I turned it off and checked the brush roll, which was fine and spinning freely...
I took the base plate off just to make sure and everything was fine.
I thought maybe there WAS a bit of thread stuck but it sorted itself out just as I turned it off - that was possible.
So I turned it back on again and it sounded even worse than before, sort of like a cat being strangled, plus the burning rubber smell was even stronger. It smelled like the belt was burning up but it couldn't be because the brush roll was rotating FINE.
I then checked the hose for suction and there was hardly any, despite the Bag Full/Blockage light not illuminating. I turned it off again and checked for a blockage, which there was none, I even replaced the bag just to be sure, but when restarted it still had pessimal suction, probably due to the motor running VERY slow.
Please tell me my old faithful Hoover hasn't died a horrible death ?
I'll give you a link to a video I'm uploading at the moment when it uploads so you can hear it, but perhaps you can help even without it. I really don't know, all I know is I'm very sad that my favourite vacuum has let me down.
That's what I thought Chris... To say I am disappointed doesn't touch the surface.
As The Big O would say, it's over...
Jamie
I am so sorry that this has happened, I know what it is like to lose a beloved vac.
But to me, it sounds like Chris is right.
I did check ebay uk for replacements but unfortunately, I found nothing.
I would take it apart and try to find out what happened, or if there is a vac shop near you I would take it there.
Sorry I could not be more help.
Scott
Agh, bad luck mate...
Maybe you could buy a cheap one of eBay, and extange the motors?
Or, just buy a good condition used unit, and get rid of the old?
Still, Rest in Piece, Turbopower....
OK, a bit more information.
When I rotate the brush roll by hand now it makes a "click click click" noise quietly, like spinning the fan on a Hoover Senior in the wrong direction.
So, it might not be such a big job as first thought. When they break. There's often that kind of sound. That's maybe because the springs are toutching the motor or what's left of the Brushes might have moved out of position...
Jamie,
I agree with the inteligence above,The carbons sound like they've "Bit the dust".
Compare your vacuum's sound witht his vacuum's sound (Just don't run your vacuum to hear the sound,Use your video to not cause the cleaner more harm!).
-Alex.
I supose its worth a try. But I would inspect the commutator first and if it is damaged, then you will need to find a new one, if you replace the brushes and the commutator is not to bad off, then I would burnish it to smooth it back out.
But don't expect miracles.
Hope this helps.
Scott
