I decided to use the 1994 Hoover Turbopower 1000 today as it had been sitting for a couple of weeks. I did all the upstairs carpets which took about 15 minutes and it worked perfectly, adjusting up and down on Autosense as required, no problems.
I shut it off, unplugged it and went downstairs then plugged it in and proceeded to vacuum the carpet in the hall way. Again, no issues.
Once I'd done that, I put it in the upright position (still running on low Autosense), moved the height adjustment to Shag/Tools, pulled the hose out and attached the extension tubes then all of a sudden the pitch changed from the quiet smooth hum to a really dull noise and it sounded like the motor had slowed down to about half the speed it was running at and a smell of burnt rubber was apparent. I immediately thought I'd caught a bit of thread in the brush roll and it wasn't spinning so I turned it off and checked the brush roll, which was fine and spinning freely...
I took the base plate off just to make sure and everything was fine.
I thought maybe there WAS a bit of thread stuck but it sorted itself out just as I turned it off - that was possible.
So I turned it back on again and it sounded even worse than before, sort of like a cat being strangled, plus the burning rubber smell was even stronger. It smelled like the belt was burning up but it couldn't be because the brush roll was rotating FINE.
I then checked the hose for suction and there was hardly any, despite the Bag Full/Blockage light not illuminating. I turned it off again and checked for a blockage, which there was none, I even replaced the bag just to be sure, but when restarted it still had pessimal suction, probably due to the motor running VERY slow.
Please tell me my old faithful Hoover hasn't died a horrible death ?
I'll give you a link to a video I'm uploading at the moment when it uploads so you can hear it, but perhaps you can help even without it. I really don't know, all I know is I'm very sad that my favourite vacuum has let me down.
