Help Identifying Canister/Tank Aluminum Fan Blades
chicagomike
Plover, WI
Is it possible to identify the Brand of the fan blade by looking at the thickness and diameter of the fan?? Or if you need more information to identify what the fans go to let me know and I will be happy to get the info.
Vac Fans
The bearing plates and fans with center hubs all seem to be Electrolux from 50s-70s.In picture 3 the left & right fans of top row and left of bottom row are the early 1205 that combined the rear fan spacer onto the fan and should not be reused as they went back to separate spacer after problems with these.These seem same as first 3 in top row of picture 7.
Other fans may fit most Lmnb type motors.
Others can add more to this.
