Headlight bulb change on Eureka
sanitaireboy99
Does anybody how to change a headlight bulb on a Eureka Self-Propelled ESP vacuum?? If you need to know how it looks like, I have a video of it on YouTube which you can find on the link below.
Light bulb change
Richard
If you look closely at the with Lenes covering the Light bulb. You will see a little nitch or notch on either side. It is the size of a reg Flat head screw driver. Just get the flat head driver behind it. Do a left twist and each end
of the light lens will pop out. When you see the bulb, just put a finger around the back side and it will into a sticking out position. Which make it easier for you to push in on it. As it is a Bayonet style bulb. Then after replacing the bulb reverse the procedure.
Norm
Kind of light bulb
Ok so i just took out the original light bulb and now i need to know what KIND of light bulb it is. Does anybody know the answer to that question??! I really need your guys' help!! Thanks! :)
