electrolux137
<div data-contents="true">
<div data-offset-key="eo1sj-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="eo1sj-0-0"><span data-offset-key="eo1sj-0-0"><span data-text="true">Fret not, my fellow Tarheels: I haven't turned my back on North Carolina Barbecue! I just wanted to try something different this time.</span></span></div>
</div>
<div data-offset-key="6rl7e-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="6rl7e-0-0"><span data-offset-key="6rl7e-0-0"> </span></div>
</div>
<div data-offset-key="6ltrh-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="6ltrh-0-0"><span data-offset-key="6ltrh-0-0"><span data-text="true">The sauce actually started out as Texas BBQ style. But then I got inspired and added the juices of fresh pineapple, mango and lemon along with some coconut water. The result is a spicy, tangy, sweet sauce that's fabulous with the pulled pork!</span></span></div>
</div>
<div data-offset-key="1tftc-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="1tftc-0-0"><span data-offset-key="1tftc-0-0"> </span></div>
</div>
<div data-offset-key="eg98m-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="eg98m-0-0"><span data-offset-key="eg98m-0-0"><span data-text="true">I cooked the pork roast all day long in the crock pot, about eight hours. </span></span><span data-offset-key="cqpkp-0-0"><span data-text="true">All day long, Doggie's and LoLo's little noses were twitching and they kept looking up at me, licking their lips very expectantly.
<3</span></span>
<div data-offset-key="bb77r-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="bb77r-0-0"><span data-offset-key="bb77r-0-0"> </span></div>
</div>
</div>
<div class="_1mf _1mj" data-offset-key="eg98m-0-0"><span data-offset-key="eg98m-0-0"><span data-text="true">When it was done, I carefully removed the roast to a serving dish, removed the excess fat, and then did the "pulling."</span></span></div>
</div>
<div data-offset-key="dtfd2-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="dtfd2-0-0"><span data-offset-key="dtfd2-0-0"> </span></div>
</div>
<div data-offset-key="a7er3-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="a7er3-0-0"><span data-offset-key="a7er3-0-0"><span data-text="true">I let the sauce stand for a few minutes in the crock pot and then siphoned off the excess grease (there was a LOT of it) with a turkey baster, and got as much of the rest of it as I could by layering heavy paper towels on the surface to soak up some more.</span></span></div>
</div>
<div data-offset-key="25kas-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="25kas-0-0"><span data-offset-key="25kas-0-0"> </span></div>
</div>
<div data-offset-key="2ob4p-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="2ob4p-0-0"><span data-offset-key="2ob4p-0-0"><span data-text="true">I then poured about half of the sauce over the pork and let it stand for a few minutes.</span></span></div>
</div>
<div data-offset-key="3ekvc-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="3ekvc-0-0"><span data-offset-key="3ekvc-0-0"> </span></div>
</div>
<div class="_1mf _1mj" data-offset-key="b28af-0-0"><span data-offset-key="b28af-0-0"><span data-text="true">Earlier in the day I made coleslaw with cabbage and carrots, along with some diced fresh pineapple to complement the barbecue sauce. It rested in the refrigerator all day, so it was quite tasty by dinnertime.</span></span></div>
<div data-offset-key="b1fkb-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="b1fkb-0-0"><span data-offset-key="b1fkb-0-0"> </span></div>
</div>
<div data-offset-key="8fotb-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="8fotb-0-0"><span data-offset-key="8fotb-0-0"><span data-text="true">I served the pulled pork over open-face hamburger rolls with a generous heap of coleslaw on top of each side.</span></span></div>
</div>
<div data-offset-key="7fe0q-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="7fe0q-0-0"><span data-offset-key="7fe0q-0-0"> </span></div>
</div>
<div data-offset-key="2qk7d-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="2qk7d-0-0"><span data-offset-key="2qk7d-0-0"><span data-text="true">"I must say," this came out GREAT!</span></span></div>
</div>
<div data-offset-key="arf3-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="arf3-0-0"><span data-offset-key="arf3-0-0"> </span></div>
</div>
<div data-offset-key="4t703-0-0" data-editor="4k4ti" data-block="true">
<div class="_1mf _1mj" data-offset-key="4t703-0-0"><span data-offset-key="4t703-0-0"><span data-text="true">We dined al fresco on the balcony, enjoying the cool summer evening and the lovely vistas around us in the neighborhood.</span></span></div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
