electrolux137
No, I'm not talking about salad dressing!!
Here's a pretty rare, funky but lovely old vacuum cleaner. It's an Air-Way "Green Goddess" straight-suction upright machine from the early 1930s. (I'm not sure of the exact date of manufacture.)
I first saw a Green Goddess in the Hollywood home of my friend Stan Kann (R.I.P.) back in 1991 when we first met.
The color scheme is very unusual! The handle is painted with metallic Dun Green, with a flakes of gold-leaf spatter-painted into the green, and then sprayed with a coat of clear lacquer. I have three of the handles and am going to use one of them to do some paint tests and see how closely I can come to replicating that color and appearance.
I found three incomplete Green Goddess machines a few years ago at a vac shop that was closing. Putting all three machines together has been a project I've wanted to do for a very long time. Now that I once again have a functional workshop I was finally able to start on the machine.
I first just wanted to make sure she runs, so I put her together and gave her a test run, gradually increasing voltage with a Variac until I got her up to 110 volts. She runs like a champ! The motor sounds great with no bearing noise whatsoever.
The next phase will be to take her apart and really give her a first-class deluxe spa treatment.
Meanwhile, here are some photos of the Glorious Green Goddess, and then a short video to see her on her first test-run at Casa Electrolux!
(P.S.: Stan Kann showed me the best way to store all the early Air-Way uprights. You don't want to leave them resting on their wheels because the wheels, made of vulcanized rubber, will develop a flat spot especially if stored for long periods of time. He said you should tip the machine up and store it on the front edge of the rug nozzle so that the wheels aren't touching the floor.)
