Good and bad Electrolux Motors?
fantomfan57
Austin Texas
I am confused, which model canister had the bad motor in it? I have a model 1401, 1401B and a 1521 (blue, white trim, on/off in english & french).
My 1521 has the phrase "Use only genuine Electrolux bags" embossed just above the inside where the bag is installed. It also has UltraLux screen printed on the surface behind the blower hole.
Some more knowledgeable members can probably answer this with a greater level of specificity, but my understanding is that a relatively small number of 1401 (Super J) vacuums received defective motors when Electrolux had to quickly find an alternative supply of motors following a fire at their motor plant. When the bad motors began failing, Electrolux replaced them with good motors and put an extended warranty on the affected machines.
The ones that were repaired under warranty usually have a sticker on them stating the extended warranty. You can also identify those machines by their serial numbers but I don't remember exactly what to look for there. At this point in time, some 40 years after the fact, I would think it fairly unlikely to encounter a 1401 with a bad motor as they have probably either had the defective motors replaced or have been scrapped. In other words, if the thing is still running after all these years, it most likely has a good motor.
Thanks, Edgar...
That makes perfect sense. Here are the shots of the 1521. The screen print label says Ultralux Classic, the Classic did not show up in the picture. It is, my favorite after my Lewyt.
There is.........
actually a discussion about this in here regarding the Super J motor. It was one of the serial # runs K----------S. Lux stood behind each and every claim and fixed them all. The five yr warranty on the motor, you'll see under the handle on some surviving canisters is testimony to that. I believe the Super J motor was the biggest and baddest canister motors Lux ever made in house. They spent over a million dollars retooling their plant to make that specific motor. It's bigger, the armature is longer etc than anything previous.
Other than that, there was an initial run of Diamond j motors that were said to shed their commutator plates. I've restored about a half dozen Diamond J's and never seen a motor I couldn't service. Somebody also said in here that due to the sandy, desert type environs there was some Lux motor failure. I've never seen the Diamond J motor failure they're talking about and.....I bought a new one about 84/85. My ex had it until her cleaning lady virtually destroyed it...motor never even flinched. But those motors were outsourced for Lux and very LOUD...compared to the classic Lux wooooosh.
I lot of it of course, depends on the quality of the bags, how full you let the vacuum run and if you're ever tempted to vacuum over something damp etc. Even the best motors can fail if abused.
Let me know if you want that link about the Super J motor.
Kevin
These wires.....
Here is a picture of the wires I am talking about.
2 white ones, do they go together piggybacked?
the single black wire has a different connector. Where does that go on the cord winder...more importantly,why is it different.
Should I change the black wire's connector and clip that on to the correct terminal on the cord winder?
Before I connect these, am I correct?
Where is the motor? The snap in connector connects to an identical female connector wire coming from the motor. I believe the other motor wire (there should be two wires coming from the motor) connects to the piggy back connector.
Did you label or draw a picture of the wires when you took the motor out? Once you have the motor in it should be more clear. I guess I'm unclear of what is going on here. Maybe I misread.
There actually a lot of motors sent in for warrantee work on the last of the metal tanks. The Diamond J, Marquise, and Ultra lux. As far as the Super J issues I don't know about those.
Now I remember.....
I did not originally take the motor out nor was I given the motor. A Vacuum Shop friend just gave me the body without a motor and cord winder.
Further, I was attempting to install a motor from a Diamond Jubilee, which I just found out is too big (??) to correctly install.
I am about to give up on restoring the Silverado. I really wanted that one restored.
(BTW, I did not click on the links above before writing this).
It doesn't.....
surprise me that there was some significant motor failure with the Diamond J series type motor...it was an outsourced motor for the first time. However, they all got fixed under warranty;as the motors failed up front, not many yrs down the line. Ergo, you had a good one or a bad one from the get go. You could also argue that the ones I restored were surviving examples and as such were either replacement motors or sound originals.
The info on the Super J motor is well documented and not up for conjecture.  They even know what run of serial numbers you're supposed to stay away from....resulting from the armatures being outsourced after the fire at the Lux factory. Read about it here, as I'm not going to quibble about it further.
That link above is invaluable....I used it a long time ago when I was reckless with a Diamond J on not taking a pic and/or writing down how it was wired. It just took one picture frame from his tutorial to put me back in business. I went to thank him for his contribution, but you can't loop back to a real person.
Kevin
[this post was last edited: 9/15/2016-13:41]
http://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?24132
don't give up on the Silverado.
Post some pics of the what the vac looks like.
We might be able to work something out.
I have a running one with a rusty shell.
Hey Sven...
Here are the pictures, I have not wiped it down yet and the switch was on the work bench inside. It looks good, but will clean up very well. The side bumpers are notched up pretty well, so I would want to replace them.
I have a couple perfectly good running machines I was thinking of pulling the motors out of, but I may not.
BTW, the Diamond Jubilee I parted out, had been treated really badly. The rear wheel mounting shaft brackets were torn in two so not all the rivets were stabilizing the wheels.
What did you have in mind?
cracked axles brackets
These vacs will usually get tossed.
I fixed mine by fabricating new ones.
(Brown Olympia One, now blue :) )
1st 3 pics are the Olympia One
4,5, & 6 show the Silverado. Bottom is all rusty.
It looks like the Silverado was kept in a very humid area.
I'm pretty sure the wiring is mostly the same from the 1205 on....so that link above where the guy breaks down the Diamond J should be self-explanatory. It sure helped me! Although as I mentioned, it worked fine the way I wired it....but according to his pics, I switched just two wires. To be honest, I didn't trace it through to see what the difference would have been.
Kevin
Curious to see what it will pull in inches of water....do you have a gauge? If you've done the motor right, should pull over 70"....some will pull 80"
Kevin
Cool....
love to hear yet another one up and runnin'!
I recently bought a Super J with dismal suction, but very nice otherwise. I bought a rewound armature for it and am looking forward to a full restoration eventually.
Kevin
Glad you got her running...
Accessories aren't too hard to find and you can go with the original or do some mixin' and matchin' for your own custom combo. Looking forward to seeing what you come up with.
I've got.......
two slightly different floor brushes that while the same color, one has the release on top and the other has the release on the side. Both I assume are around the Diamond J period. I'm gonna guess that the side release is newer, because I've never seen one before, as all the floor brush tools back to the G have a top release. No big deal and as long as the color matches, I mix & match accessories.
I've got a tan upholstery brush with green wings. I always thought that was just a repair, but I've seen them for sale like that on eBay.......which makes me wonder if they were ever a production piece in those colors?
Kevin
Red Text "Use only genuine Electrolux bags"
Regarding the red text on the rim of the bag cage, here is information from BrianKirbyClass's reply in this thread: http://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?17012
"I heard an Electrolux Branch Manager who had been in business for over 40 yrs, say once that any Electrolux cannister with the RED lettering above the bag compartment that says "Use Only Genuine Electrolux Bags" in RED,, may have motor issues sooner or later, as a different(Cheaper and problematic) motor is used.
The bad news is that i think all models from the Diamond Jubilee on have the red lettering,,and ive seen some Silverado's with the red lettering also.
This Lux Branch Manager said that he had NEVER had ANY machine WITHOUT the red lettering come in because of early motor trouble or early burn out,,but had MANY, WITH the red lettering that DID have severe motor trouble. Infact,he said that some motors were burning out within DAYS after purchase. (Evidently the Marquis was the worst offender.)"
I hope mine is okay...
I has lasted all this time and I actually ran it last week, no problem. Having lasted this long it may be that this one was replaced. I would have to look at the motor itself, but I am not motivated to take it apart at this time.
Yeah.....
it's hard to speculate after all this time, if a canister has the original or a replacement motor....unless there's a stick with the five yr warranty like on the Super J's.
Kevin
So I switched my Super J...
for the Silverado, to finish up the vacuuming. It was then I noticed I had not cleaned it up before bringing it inside from the shop.
I would REALLY like to replace the side bumpers, these are really rough in that there are nice size chunks "bitten" out of them. They are the bumpers with the "fins" instead of being flat AND, are grayish instead of beige-ish. If I find another set, I think I will have to warm them up with a hair dryer in order to make them easier to handle/manipulate.
Does anyone have any tips on replacing them?
Use of a hair dryer is an excellent tool, as they have to stretch a bit to snap in. Or a heart gun on its lowest setting.  I found some nice bumpers on eBay for my Super J. The faded lettering I went over with the appropriate colored Sharpie...looks great/fresh.
Kevin
Just to point out--in case you hadn't noticed--the bumper logos on the 50th Jubilee 1205 and the Super J 1401 had black lettering with a gold border; just as the teal 1205 had black lettering with a red border. Both were black on the Olympia One 1401, 1401-B, & 1505 and the Silverado 1505. Some have been redone in all black over the years, which has obscured the original colors.
The Deluxe Special Model 1453's bumper had a recessed logo with raised lettering, so only the letters were black--at least on the brown and gray ones--they were likely jade on the DJ-colored ones.
