DesertTortoise
- Joined
- Jun 6, 2014
- Messages
- 1,189
If you served in the military, and maybe if you didn't, you know what it stands for. Putting an electric motor into water is FUBAR, but if that is what it takes to get rid of the stench coming from my $25 Starvation Army Electrolux shop vac ( ! ) then soak it in water is what I will do. It's not like it hasn't already been wet before as my images show you.
I took the vac apart again (getting easy to do now), removed the motor and took the big black prophylactic it's hidden under off it. The brush housing came off surprisingly easy releasing the fields, and I very much like how Electrolux uses little coil springs to effect contact between the field and the brush. But it appears to my untrained eye that brushes are not replaceable on these motors? Is this true?
I was careful not to immerse the armature, though the bottom bearing got wet, and the armature got a little wet when I blew the thing out with compressed air. I think the fan no longer has any smell but I can still smell something from the armature.
It is sitting on the back wall in the hot desert sun to dry out and hopefully air out.
I also figured out how to remove the bag compartment. It releases by pressing down hard on two tabs accessed from under the belly of the main body. That also frees the door and all the wiring for removal. You can see the splatter on the circuit card. This poor vac was really abused, and judging from how much brush it has left, it doesn't have a lot of hours on it. What a shame to ruin something so expensive and well made through such thoughtless abuse. Anyway, it'll live again but this one is going to make me work hard for it. No simple morning in the sink like most of the Kenmores have been.
The summer of electroluv continues .....................
