Westinghouse canister rebuild
mopep
Saint Louis
I need a fan for this Westinghouse canister which we used regularly until the fan broke ('cause someone used it as a wet vac.) Model VPC 04001, probably from the mid 50's. As you can see in the photos, it is definitely not a restoration as I've had to fashion a new handle and replace the wheels with generic wheels.
EDIT: Ignore the motor part in the photo. I just need the fan.
    295.3 KB
    292.5 KB
Jimmy is in the process of closing his Elizabethton, TN store and has a large inventory of cleaners and parts. Reach out to him at 423-268-4841.
I wonder if your Westy was rebuilt at some point as the ads withI located in a digital newspaper database for Westinghouse canisters began with the single- or double-letter prefixes followed by 1- or 2-digit numbers. Another possibility is that, like G-E, the model number was embedded in the catalog or product number. Using that line of thought, yours may be the model VC40. Other canister model IDs I located from 1962 to 1971 with the same prefix were VC10, VC15, VC20, VC25, VC30, VC31.
Anyway, I hope you find a replacement fan.
  • 1961 Jun 1 THE DAY -  Vacuum Bag List including Westinghouse canister models CD 8, DC, NC, SC.png
    64.8 KB
    171.1 KB
  • 1964 Apr 8 PITTSBURGH PRESS - Westinghouse canister vacuum models VC10, VC20, VC30, VC31 ad.png
    334.6 KB
    94.9 KB
    61.6 KB
    192.7 KB
P. S. (For reference) Just noticed that the 1968 ad is "VS-25", which appears to be an error as it was run only one day in that one newspaper. I did, though, find several others with "VC-25".
What you show in the second image is the fan attached to the armature. The fan doesn't appear damaged in that view, though damage might be hidden out of view. Is it the fan or the electrical part, the armature, that has the problem?
I agree with Paul, that your Westinghouse canister was built sometime in the 60's. Here is a pic of my Westinghouse SC-1 Canister which was built in 1956. It's a special vacuum in my collection, as it belonged to my Aunt Lu (my Dad's sister), whose husband worked at the Mansfield, OH Westinghouse plant for most of his career and retired from there. I got the SC-1 when they moved into assisted living. An interesting fact about the Mansfield plant is that although it was the headquarters of the Westinghouse Appliance Division, vacuum cleaners were never made there, but made at another Westinghouse plant in Springfield, MA!
Wishing you the best of luck in finding the fan that you need. And remember, "You Can Be Sure...if it's Westinghouse!"
It sure looks like one of those, so VC40 is a good guess. The model number is stamped into the metal on the bottom. There are no other numbers except for electrical specs. There's a place for a serial number, but it's blank. There is something stamped with ink closer to the wheels which might be a date code: 19AR. I can upload pictures if you'd like to see. I guess it could be early 60's. It was discarded by my inlaws around 1975. All it needed was a new power cord.
The fan is missing a blade (or fin) which flew out and was mangled. I contemplated trying to take it apart and fashion a new blade, but success with that operation seemed unlikely. The damage was due to some unknown visitor who used the vacuum to clean up a wet mess without telling me. It was a dry mess before the next time I went to use it. It only sounded funny for a few seconds, and then it broke.
Oof. That sucks. What is the diameter of the fan? Maybe you can adapt a fan from a single stage Ametek motor? You might be a very long time finding a Westinghouse replacement.
Yeah, I would like to see a photo of the specs. This site is richer when details like them are shared and the "puzzle pieces" can be fit together. Sounds reasonable that the 19AR is a date code.
Btw, Doug Smith, a Canadian collector of worldwide surface care appliances, has a website of his collection (http://smithcollection.altervista.org). Two of them are similar to yours: a Westinghouse Poweraire VC25-2 and a Coronado D150. There may be others as I only did a cursory search.
    333.3 KB
    310 KB
Jimmy makes a good point, mopep. Dysonman1 (Tom) probably knows; you could pm him. Otherwise, you could reach out to Doug Smith. His email is on his homepage at the end of the intro.
Buying a Westy from Jimmy as a parts machine, if he has one, would probably be your best bet.
OK, here are some more photos showing the name plate, possible date code and more views of the fan. The mounting holes for the missing vane can be seen in the top view of the fan. Critical dimensions of the fan are:
Diameter = 5.5",
Thickness = 0.4" (includes .1" lip on the bottom side)
Motor shaft hole = 0.35"
Inlet hole = 1.87"
    296.2 KB
    299.7 KB
    284.6 KB
    298.2 KB
    291.9 KB
If the fan can be taken apart by unhooking all of the blades, I feel like you may be able to find a sheet metal manufacturing company who can either replace the blade or make a new fan from scratch.
Rebuilding this fan disc, or replicating a whole new one, is the only way. You will not find spare parts. Many vacuums take 5-10 years to find someone with parts. I have been on the hunt for 8 years for a Hoover Z400/700 access door plug and nobody has one.
You can likely rebuild the fan vane yourself with pop cans, this is all just held together with crimp tabs.
In reply to a few earlier comments:
1. To Paul: I did contact Doug Smith. While he does not have any parts that I could use, he did say this, "I suspect it may have been a Lamb motor, in which case the parts are relatively easy to find." I am posting some photos of the motor and its mounting in case it helps identify the source and/or any possible cross-references. I could not find any identifying text or numbers on the motor or fan.
2. To vacuumman and huskyvacs: rebuilding the fan is probably beyond the effort I'm willing to make, in part, because success is a gamble. Unbending the tabs that hold it together risks stress fractures and breakage. The top plate of the fan (see earlier photo) is missing some metal at the outer edge where the broken blade tore loose so attachment and balance are both issues that I'm unsure about. Finding a machine shop that could and would take on a rebuild project is possible but perhaps just not worth the cost. For now, I'm hoping a simpler solution appears. I'm hoping that the photos I've posted will generate more ideas as to where a match might be found.
NOTE: the motor rotor is shown in an earlier photo attached to the fan.
    293.5 KB
    297.3 KB
    296.9 KB
I wonder what kind of cutting accuracy you could expect from sendcutsend.com. You might be able to reverse engineer the fan and order new precut aluminum, and assemble it yourself.
(It kind of does look like a Lamb motor fan, not that I'm an expert.)
I would be real darn tempted to try an Ametek fan for fit. A lot easier than trying to recreate an ancient part from a manufacturer long out of the vacuum business.
The issue is the size of the Ametek impeller - it looks too large. The other thing I would worry about is you can destroy the motor by throwing the motor out of balance with an improper impeller fan assembly.
https://www.blaubergmotors.com/news/how-to-keep-balancing-of-centrifugal-fan/
Genuinely to do this right, a metal fabrication shop replicating it would be the only way.
Without an Ametek fan to compare to we are guessing. I am suggesting it might be less work and maybe yield a better result to at least size up an Ametek fan and if the size is right use it. But you don't know for sure unless you have one in your hand to compare. I have done motor part swapping like this in the past because I had motors that had a bad part but wanted to make use of the good parts so I have done Frankenmotors. As long as the physical dimensions are compatible you can do stuff like that.
