Finished my "what is it" vacuum
ohiovacuums
Ohio
I saw this on Facebook labeled "pick up only" for $ 10.
The guy was nice enough to ship it to me for $ 15.
I like it but what is it used for ?
The base has holes in it so it appears that it was mounted to a base
perhaps with wheels. I'm going to do that next.
I thought it was industrial (maybe for wood or metal shavings) but the bag was full of dirt. It did not run when I got it so I rebuilt the motor and rewired.
It's not what I really collect but I couldn't pass it up.
Wow!! Looks excellent! That is for sure a GE product, or at least the motor. Maybe the holes were to mount to a table?
impressive  premitive  work   bench  vacuum  i like it alot  thats really  neat   could you  upgrade  to a plastic or vinyl hose   that would for sure suck  more  .(original fitting on a new hose maybe shome how ?
bench vacuum
I think you guys are correct.....a bench vacuum. It does have good suction. Maybe I'll mount it on my workbench and use it.
Thanks Hoover 300 for the tips on getting the fan off...you were exactly right.
Since it had “regular dirt” in it, not wood shavings or sawdust, maybe it actually came from the workbench of a vacuum repair shop? Used to clean out vacuums that came in for repair?
Yes, It is likely a factory made vacuum tool for vacuum repair shops. Like that Hoover bag cleaner thing. It looks like it's all there and original, so it wasn't used daily or it would be in a lot worse shape. You'd put it on a workbench and use it to clean out vacuum bags. Some oldtimer with his own shop likely had it since it was new.
wow - that's even better
A vacuum repair shop vacuum....I hope it is.
I can't find anything on it but I'll keep looking
thanks
dave
