T troopersam Member Joined Mar 26, 2018 Messages 10 Location Perris Sep 23, 2012 #2 The accessory power outlet on my 360 has failed. For those that regularly perform repairs, is this a pretty simple problem to fix? Thanks in advance!
K kirbykid63 Well-known member Joined Jan 7, 2008 Messages 611 Location Wilmington Delaware Sep 23, 2012 #3 Yes The filter queen is easy to disassemble,remove the screws under the handle and lift the dome and replace the socket its simple.
S sbakerde Well-known member Joined Aug 6, 2012 Messages 243 Location Millsboro, DE Sep 24, 2012 #4 Which outlet? Do you mean the outlet on the canister or the connection in the hose handle? If your canister outlet isn't working you may need to replace the PC Board.
T troopersam Member Joined Mar 26, 2018 Messages 10 Location Perris Sep 26, 2012 #5 The outlet on the canister is correct. And replacing a PC board sounds a bit on the pricy side.
T troopersam Member Joined Mar 26, 2018 Messages 10 Location Perris Sep 26, 2012 #6 Oh, I guess not too pricy. http://www.vacpartswarehouse.com/ProductDetails.asp?ProductCode=FQ-3660
