Fantom Hose
sheetstyler
Mooresville
I am looking to get an original Fantom hose for the first Fantom. I just got this machine and the bottom cord hook is broke and the hose has a little hole in it. If someone has a hose with the bottom cord hook attached to it. Please email me at [email protected].
Extension hoses are fairly easy to find. You can modify them by carefully cutting them to replace the wand hose. If you find the bottom part of the hose assembly with a good cord hook or entire piece with a bad hose you can essentially make an entire new hose using them. I've done this multiple times. If the hole is at the top or bottom of the hose you can cut it and the bad portion but it obviously will slightly shorten the hose but it's a good fix if it happens right near the top.
Erik....
I have done that same thing with Dyson DC07 hoses. Not sure if the other models allow one to remove the split section.
Found the instructions on Youtube....I think.
I am looking for the gray hose. That came with the model pictured in the post. The hose for the actual vacuum not the extension hose that is gray. Which matches the machine. Sorry for the confusion.
