Even More airflow tests (part 3)
Yeah...
Initial testing with the NSS has been....lower than anticipated I think i was getting about 118 hose cfm off a 1.5" diamater hose. It will be undergoing modification to get a disposable bag in it though. The original "leather" filltube was all torn up.
Anyways I just finished cleaning this up today. It's not bad, but not great. The nozzle also has quite a bit of dead space. I had one of these a a number of years ago under the sanitaire name, but it was bagged instead of bagless.
Hmm
I knew it was a pig. You forget the vacuum bag is the size of a freaking garbage can. It may only run 120 cfm but how many vacuums can inhale a garbage can and still be pumping 120 cfm. It's a pig because it eats everything including the big bad wolf. It doesn't inhale the fastest but it inhales everything.
How many?
Well...I'd assume most backpacks could. They don't have the same capacity as the M1 though. I was just disappointed because I had such high expectations for it. With the Giant 8" diameter fan I figured they could really move some air. Perhaps once I have my bag conversion in place I'll re-test it, having a smooth airpath instead of the raggedy cloth filltube may improve it.
I think the same thing for the Pig bags-get rid of the cloth fill tube and go to one like that Kirby has.The Pigs cloth fill tube can trap debris in between the cloth tube and the metal tube just inside it.And the cloth fill tube can get damaged by debris going thru it from that HUGE fan.One of my bags fill tube was shredded after cleaning up a basement reno job.The Pig gulped the stuff down better than any Shop Vac type vacuum.Fan was undamaged--it ate conduit box slugs(bent them over)A 6" piece of 14Ga Romex cable-many nails and cable staples-wood bits,sawdust,plaster dust.Had to replace the outer bag.My friend paid for the replacement.It was fun listening to the pig dinging and thooping that stuff into the bag!That Pig is still going strong to this day!!!!Contrast that to many shop type vacuums where the motor was killed by plaster dust and moisture.
Another
This is as far as I go with this machine. I can't see myself investing anymore money into it with measurements like this. It's a neat machine though and much easier to clean than Rainbow. Machine measurements would have been a pain and likely inaccurate it has a square inlet and when the hose isn't plugged into the machine it runs on low speed for air cleaning.
Another Shark
The L denotes the hard floor setting and the H for carpet, Low and High. I didn't measure the opening for CFM density as these leak a good amount of flow through the front so I wasn't sure if the front roller should be included as part of the nozzle opening. There is a suction relief valve in this so the suction listed isn't it's full power.
More Lindhaus!
A friend of mine purchased this to clean hallways and vacant apartments. I measured it with both the straight suction kit and the Electric kit. This is a backpack vacuum, but it can be converted to a canister with a wheel kit.
Yet another backpack
As far as I can tell the difference between the SC530 and the Sc535 is an added hepa filter.
I've gotta say 105 hose cfm is pretty poor the Proteam FS6 manages nearly 150 CFM with the same 1.5" hose. The difference is quite noticeable when you're cleaning with them the nozzles have more sticking power when you're using the proteam.
A hoover
This is one of the newest additions to my collection. I think this may be the best featured commercial vacuum for the price. Long life belt with a hall sensor, two speeds, easy to use onboard tools, a pigtail for easy cord changes, height adjustment, decent bare floor cleaning, both charcoal and hepa filtration are all included. I'm unsure of it's reliability over time but when your other mid 200 commercial options are very basic machines like carpet pro this is a great option.
For those unfamiliar with them they remind me more of a windtunnel upright but with some additional features.
Finally!
The NSS M-1 This is a 12 amp version.
The original leather-like filltube was replaced due to the last one being torn to hell. This change most likely does effect it's flow. Due to the odd design I'd say the Kirby filltube most likely improves it.
Strangely there's a sticker on the side saying it has 117 CFM at a 1.5 orifice which matches up with the hose CFM.
As we can see the machine airflow is ridiculous! It was actually able to hold the vane in place.
Regarding the hose airflow I checked the hose for obstruction before testing and have tested it briefly before getting somewhere around 115.
Do you have a bag that has the original cloth fill tube to compare to the "Kirby" fill tube bag?This is a good idea to repair bag fill tubes that are worn.When I helped remodel my friends home years ago the cloth fill tube was torn up from nails,cable staples,romex strippings and even a piece of unstripped romex .Found these in the bag-at the time did not use a paper bag-just the cloth one.Had to go to Winchester,Va to get a replacement cloth bag and a pack of paper bags.My friend payed for them.Use a paper bag in the new cloth bag to clean out his fireplaces-worked well!!!Put the paper bag in the metal trash can in case of live ashes.Those can withstand trips thru a vacuum!!The NSS cloth fill tubes can't with stand hard stuff ingested by the fan.The new Grey bags have a different cloth fill tube.Would like to see NSS use rigid fill tubes-like the Kirbys.So-when a cloth fill tube goes in one of my NSS bags will try a Kirby fill tube.And you can use the bag alone without the paper bag if desired-good for heavy bulk pickup.The NSS did better than the mans Craftsman shop vacuum in picking up stuff.Also bought a power nozzle for the NSS from the Winchester VA place and my friend loved used the NSS(he calls it"THE BAG"! The powernozzle pulled up all kinds of stuff from the carpets.Paper bag was full!!Those can hold several gallons of debris.
Samsung.
So this may not be entirely accurate mostly due to the wand's damage. I did attempt to epoxy it after being shattered in shipping but i can't be certain it's performing as well as a new one would.
The filter was also filthy when I got the thing. Out of concern for it, even after washing it I felt that the filter may restrict too much airflow so I tested it both with and without it.
The suction increased from the machine base to the hose, the reason for that is the empty holes the hose would clip into, they leak when the suction guage is put to the base.
The other thing to note is unlike most machines where I use the full width of the nozzle for calculating nozzle area I decided not to do that here. Why? There's no side air vents on this powerhead there's a lot of dead space (about 2.5") on the sides of the brushroll. Full Width ~12.75"
Perfect C101
The nozzle is awful! It leaks horribly. To my knowledge there's nothing wrong with it. Interestingly I got the same airflow reading with the nozzle running.
An unusual machine
The sanyo transformax uses a turbine head that is, I think, unique to it. The pedal either opens or closes an airpath that bypasses the turbine. when it's open it allows more air to flow at the cost of less force to run the turbine. When it's shut the turbine receives more force but airflow to the surface drops. What I found interesting is that it's an open vane turbine which I have only started to see in recent years. I have to wonder if this is where the open vane turbine started. at least in in a setup like this.
An older Lindhaus
This has been in the works for a while and since I took the time to get it cleaned out I figured now was a great time to do it.
Interestingly despite it's low flow it appears to be a great cleaner as it was also given a 10 pass sand test. Unfortunately after prepping the area I started to clean as soon as the sand was down forgetting to work it into the pile so the bag was removed and re-weighed. After all that I ended up with an incredible 89.6% pickup surpassing all tested uprights so far.
Upon receiving such a high number I investigated by cutting the bag open (picture 2 and 3), we can see that the pickup is a little bit contaminated so it's not quite as high as thought but it still did an excellent job!
Previous testing showed around 50% pickup but I've discovered that during that first test there were multiple issues with the machine. 1. the baseplate was installed incorrectly 2. the brush motor had a worn bearing 3. the brushroll had an end cap full of crap. Since then I've given it a motor and brushroll swap from a donor head it's performing much better now.
Miracle Mate
So a few notes about this. The nozzle leaks it leaks around the blue band which is for the edge cleaning air channels. I also know I overcalculated the nozzle area due to my inclusion of the channels but I figured it is distributing flow to them too. It did better than I thought it would but I shouldn't be surprised. I guess with the suction numbers I've gotten I was expecting a bit less. Pic 2 for the underside of the nozzle
Kenmore Elite 800 series
We have a new record for canister hose airflow beating out the previous by about 3.61 CFM
With all the joints/connections, and the narrowing airpath we saw a massive loss in the nozzle.
I See A Massive Suction Loss
Which is by design. Still, what a shame to lose that much from the hose to the PN.
From Hose To PN: 90-16=74" Loss
From Wand To PN: 76-16=60" Loss
Thomas Rectenwald's hot-rodded 12A Lux Marquise pulled 91 CFM paired with 38" of suction. It's a real bear to push on pile carpet.
Bill
Soniclean!
It's specs are in line with other light weights like the Simplicity S10P or the Oreck XL-21 Though it has a larger nozzle opening reducing the concentration of it's airflow.
