Europe to cut power of vacuum cleaners to save energy
Hallelujah!
Finally, some good news.
I had to chuckle when I read the heading: "The cleanliness of Britain's homes is being threatened by European bureaucrats who want to reduce the power of vacuum cleaners in a bid to cut energy use."
How the hell (pardon the blasphemy) is it threatened !?
This is a damned good thing because it means manufacturers (mainly ones making bagless Vacuum Cleaners) will have to design them MUCH better to achieve acceptable suction power. In fact, I don't even know if it will be possible to have a bagless Vacuum Cleaner for 1960s wattages...
This could turn out even better than expected and actually end the bagless market and return to low wattage bagged cleaners. THAT would be something worth celebrating... Or not, depending on the side you take on that everlasting debate.
You know something, I haven't been happier all month!
Thank you for posting this Chris, YOU'VE MADE MY DAY! :)
Having read that article again, I now realise how inexperienced (there is no other word for it I'm afraid) the "experts" are.
They say it will reduce the effectiveness for picking up fine dirt... Umm, no! Not with a good brush roll. And as for cylinders, well, do what America does and fit Power Nozzles.
All manufacturers need to do is look back on history and see how Hoover got the dust out of carpets back in 1908 - BEATING.
Of course the method would have to be changed slightly to make it compatible on glued down carpets, but it could be done.
I'm just glad my carpets aren't glued so I can use my good old agitators for dust removal, even if it does let some back into the air via the poor filtration, or even better use my Turbopower 2 and 1000 with the activators which work nigh on as good AND have good filtration.
Its all political propaganda, the EU is full of it, they love to control. The vacuum company's will rebel and so will consumers.Consumers like power. Vacuum's, cars all the same, thats why BMW 3 series outsells the Ford mondeo in the UK, Power.
I tell you what though, if they do manage to make it law you will be able to make a nice living turbo charging vacuumcleaners.
I don't know if you have them over there, but a few years ago, Eureka (Electrolux) was selling the "Enviro Vac", a lightweight bagless upright that they claimed had the same cleaning power as a normal upright. If I remember correctly, it only used 8.5 amps (99% of new vacs over here use 12 amps). I never had the oppertunity to use one though. Also, Bissell is using lower wattage motors in their low end uprights sold at walmart, I think 10 amps.
We already get allot of it, however what I do is fit a curved turbine ametek motor into older vacuums to increase the airflow, it works a treat. Customers always ask us to fit a more powerfull motor IE wattage but often the motor we fit uses less wattage than the original one but sucks better
