dustin
I have started using a Eureka ESP upright, model 2330 to clean our church because it picks up more dirt than any other vacuum I have tried. the problem is that it constantly burns up the belt. with a brand new belt I can vacuum for about 20 minutes and then the belt needs to be replaced because the brush is stalling even on flat carpet. when i change the belt, everything is turning smoothly. the brush strips are pretty worn but still work(it has the vibra groomer 2 brushroll in it) it just seems like the belts should last longer than they are. before I started cleaning, i was letting the person that cleaned the church use it because she hated the vacuums that the church had, and the belts were lasting about a month. why is this happening? I also have a Eureka 1934 that is basically brand new that doesnt have very good suction and I cant figure out why. the fan is fine, and its not clogged. the 2330 has the 6.5 amp motor and the 1934 has the 5 amp motor. THANK YOU!
