Electrolux Special Edition 1623
For a very good penetrating fluid, you could try mixing automatic transmission fluid and acetone 50%-50%. Its smells strong but it is by far better than WD-40 for loosening metal parts. I've used it with very good success in many occasions. YOu should store the mix in a glass container with a tight cap, acetone will melt plastics.
Thanks, Bill & Francois. I really appreciate it.
The fan casing was pretty rusted, so I'm thinking the cleaner may have been stored in a basement. Anyway, I kinda chewed it up trying to open it after spraying it with WD-40 yesterday; maybe I should have waited on that one, too.
I'm also not having success removing the brushes by pulling on the tabs with the pliers. Please advise.
WD-40 is not penetrating oil and anyone who uses it as such is suspect in my book. It is purely a cheap water displacement formula originally intended to spray inside engine distributors that were wet with moisture. It's not a lubricant either of any worth.
Kroil is a first rate rust penetrant, then Liquid Wrench followed by PB Plaster which is available most anywhere. You could also mix your own like  François indicated.
<p style="margin-bottom: 0in;"> </p>
Kevin
Thanks, Kevin.
Since I had the WD-40 on hand I used that so will wait to see if it works like it did on the fan casing. If not, I'll try one of yours or Francois's recommendations.
No, I wasn't able to get the fan off. I haven't had the time to work on it lately but hopefully will be able to this weekend.
Thanks for asking. I'll keep you posted.
I'm in a quandary. I was unable to remove the motor bridge after removing the two bolts nor could I get the motor brushes out, so I took the motor to an Aerus dealer to get some in-person advice.
As he looked it over he reasoned that it overheated while running for an extended time due to the black film on the commutator, the overheating residue in the second fan stage, and the inability of the motor bridge to pop right off (he surmised that it had melted onto the magnets). He also mentioned that the motor brushes were not meant to be removed, because of thermal protectors; which is why I couldn't get them out.
He mentioned that he could replace the motor for me for something like $449.00, or sell me a motor for around $385.00 that I could install myself. Ouch. No thanks.
Do you think I should still try to remove the motor bridge and resume my project? I'm toying with the idea of squirting some Liquid Wrench Penetrating Oil on it but don't want to mess with it if it truly is a lost cause.
Here's the alphanumeric code and ratings on the fan casing, if that tells you anything: B-9 ECP 6500-253 10:39 68Hz BJ 20 120VAC SERV
What to do?
The ebay link is for an Electro Motor 6500-293.
You can google it to find a cheaper price.
Specs can be found here:
http://electromtr.com/through-flow-motors.htm
About the company:
"Our History:
Electro Motor purchased the motor business from Aerus, LLC (formerly known as Electrolux, LLC), and took operations on July 1, 2002. This former Electrolux motor business has built high quality floor care motors for over 60 years. This tradition of motor design and excellence with an emphasis on durability, quality, and exceptional customer support continues with the new Electro Motor ownership."
http://electromtr.com/about.htm
Thanks for the suggestions and links, Bill & Sven. I really appreciate it.
The lowest price of the motor I was able to find online was around $70.00 with s/h. I'm first going to see if I can get a used one from a local vacuum store that I can rebuild.
The Aerus dealer has a bunch of old Electroluxes in two back rooms and a basement, but he wants $100 a pop; so I'm not going to go that route.
It's too bad he's wanting to see junked machines. I've had vacuum shop owners give me that stuff just to get rid of it, including NOS vintage parts that they knew would never be used.
Yeah, he's a mercenary.
Also, he has no regard for collectors, enthusiasts, or anyone on a limited budget that he could help by rebuilding them and selling them—or their parts—at modest prices. I'm not sure, though, if he's kept any of the hoses; so that would be the cost prohibitor.
