Hello,
I am trying to repair an Electrolux Model L canister vacuum for a friend who is 89 years old and the original owner of the vacuum. She absolutely loves the vacuum and I'd really like to repair it for her. Our friend uses the vacuum regularly and the problem just started. It runs for a bit, then stops. When running, the armature looks like a 4th of July hand-held sparkler.
I have removed the motor from the vacuum. The carbon brushes are only about 1/4" long and barely extend out of the holders. The brass holders seem very close (too close) to the armature with less than 1mm space, if that, but I don't have the experience with electric motors to know if that's OK or not. There is a 1/8" space between the brass holders and the outer end of the plastic brush covers (the plastic piece which holds the brass holders) at the end cap end. The brass holders look as if they've recently made contact with the armature, but armature still looks OK, not great, but no major grooves that I can see. The bearings appear OK.
I’ve ordered new brushes for the motor and hope they are the correct ones. I’m concerned about the clearance between the brass holders and armature as they sure look too close. I'd love to hear from anyone who has rebuilt this motor and can address my concerns about the brush holders being too close to the armature. How close should they be? Any other tips would be appreciated too.
And, by chance, does anyone have a replacement motor for this vacuum?
Thanks for your help,
Greg
Greg
