Electrolux model "E" through "L" wheel replacement.
crevicetool
GA
I had the honor of hosting Toby Glenn at my house this time for a fix 'em up / mini meet. One of the operations was changing out the rear wheels to Toby's model "R". Since this question has come up more than once on the forum, I thought I would do a photo essay on how I do it. I've had great success with this and it almost looks like a factory job. Enjoy, and hope this can help someone out sometime.
Busted wheel....
I remove the rear housing, and grind off the original "fastening system" which is really a washer being held in place by flared section of the axle.
Sorry for the fuzzy picture......Toby had had eighteen Margaritas by this time!
For 18 Margaritas I would say that was a great picture!!! It was fun talking with you guys I know that you must have had a great time!! Glad too that you are showing us how to go about changing out broken wheels. Terry
Let's see, where was I before I was so rudely interrupted by Terry? Oh yeah. Then, I replace the wheels with new shiny ones. I prepare an 1/8 inch pop rivet by pulling out the "stinger", apply J B Weld to the newly drilled hole, re-install the washer, and insert the rivet.
Then finally reassemble the machine, and while the fit is pretty tight, I like to put some tape around the wheels until the epoxy sets up. Other than that - it's a done deal. You only have to do this to one side of the axle to replace both or just one wheel.
So sorry about that but you know me, I just had to jump in there!!LOL You are right, they do look like brand new factory intalled wheels.
We also repaired all of the wiring of a GE swivel-top that just, well - wore out. We had fun playing with the WestySig. What an interesting machine!
The "hub cap" on one end of the machine un-clips, exposing the blower port. When the cap is in place, exhaust air is diffused around the perimeter of the 11" wheel! Here it is with the hose attached.
Then we ate a Lasagna dinner, and spent the rest of the evening looking at old vacuum magazine ads, vacuum manuals, and watched a video Toby had recorded a few years ago. We all enjoyed Toby's visit so much. It was a pleasure.
As usual, No Terry Lattz's were harmed in the making of this photo-play.
yet.
Thanks Toby!!!
BTW I am one model 200 Filter Queen richer now too!!!
Excellent Methodology and Tutorial, as always, Rick. Should I ever have to do that, I'll do it your oh-so-neat way.
So the Westy-Sig is a Roll-Easy 'breadbox' with fins and a luggage bin and wheelie bars out back. :-) very cool machine.
Really want to see more pictures all around and inside the Westy-Sig, Toby.
Fins, luggage bin and wheelie bars! Also loaded with a big block 396 bored & stroked, 12-1 pistons, and a high-rise cam with roller lifters. Four speed crash gear-box, with a short-stroke Husrt shifter, all in back of a explosion proof bell housing.........(huh?)
An unusual hose coupling. When you pull that slip ring, it retracts a lock. Sorta like an incline within the ring. Works very well.
It's interesting to note that Toby said his Westinghouse version of this machine HAS a separate blower port. It didn't occur to us tonight that there was a port - so we hunted it down! The machine really has great suction. My garage has those 6' X 8' carpet sections from Home Depot. The rug tool picked the carpets up about eight inches before letting go. Really fun machine.
