Electrolux E-2000 question mark light
Nikita, that question mark light comes on if you have no bag installed - it's a failsafe to protect the vacuum from being damaged by dirt due to no bag being in the bag compartment.
It could be the bag door contacts have failed. There is a set of 3 prongs that match up to 3 receptacles on the bottom of the bag compartment. Occasionally, those go wonky on the AP series and E2000 and require sanding down lightly or replacement entirely. Electrolux abandoned this design on the next model, the LE/2100, in favor of putting a single contact pole the bag door presses against in the bottom of the bag compartment.
Make sure your bag does not have a bent collar - if it does, that would be why it isn't pressing the button on the bag door. Try another bag from your pack, if that doesn't resolve your issue you will have to take it into a shop for servicing.
