loganvac
Hi, all. I'm currently rebuilding this Electrolux Discovery Special Edition that was given to me by my aunt. I just cannot figure this thing out. Being mechanically inclined to fix many things, mainly vacuums, I am not used to being so perplexed by a seemingly simple vacuum. To begin with, I plugged the machine in an outlet outside for good measure. Luckily, this good measure came in handy, as white smoke was rising out from the motor and the top of the bag cover as it was running. This vacuum is a duel motor vacuum, which I new from the start. The motor that spins the roller worked fine. The suction motor wasn't so lucky. It was moving rather slow and it wasn't very loud at all. After maybe eight seconds, I saw the smoke and quickly turned off the vacuum and unplugged it. The motor also had barely any wind down. So my first question: Is the suction motor able to be repaired? Moving on, I obviously want to get to the motor. I started to disassemble the cleaner head and took off the handle. That left me with the machine body, which is the bag cover or holder and motor housing, which is where I'm at with the cleaner now. On the lower part of the body are the two bottom cord holders. Also, the cord enters there in between the bottom hooks where it connects to the motor. I inferred that the body is two pieces. Is this true, and if it is, how can I safely take the bag cover or holder off of the bottom part of the body that holds the motor? I can't get it off. Thanks in advance for the help and advice!
