Electrolux AP100 ✨✨✨
Nice
I'll say this those old electroluxes look like summer vacation movie with Chevy Chase driving that station wagon. There not great looking.
I will say it's mint. The salmon color is nice. How is it every vacuum is mint.
I'm on lookout for a dual sanitronic 80 green extension tube. Since you have a knack for pristine vacuums if you could look out for a d80 tube I'd appreciate it.
Difference
The one with 6 lines is use the hose on carpet and upholstery. The other is to use in hardwood and tile.
I think what Les was trying to say is that there is both a bare floor tool AND a carpet tool as well as the PN. The carpet tool is identical to one of the versions of the ever popular US model XXX nozzle.
If I am correct, the PN on this machine has 3 different brush roll heights adjustable on the nozzle. It's been a long time since I've seen one! Greg
Nice find ! I have 4 of them in my basement, but none as complete as the one you bought.
The color is actually beige, light beige for some parts and dark beige for the others.
THe motor is pretty durable, most of them need a bearing change and brushes change, that's about it.
THe weak part is the hose, most of these old fabric-like hoses aren't airtight any more, so succion at the end is sometimes close to nothing.
I was informed that this Canadian model Electrolux was one of the first plastic models manufactured in 1974. I snapped it up through an estate sale broker for $25.00 🤙🏾
Hey Keith! That’s a really nice one. Love the Canadian luxes! Would love to find an AP100 or AP200 in mint condition like that! Any suggestions how to come across one in such great condition?
Best,
John
Lesss ..lol..heyyy dude! Thx for the props! I will rub my magic lamp for you !
I have the Electrolux AP100 but the second edition. Where the power nozzle in the 1st is PN V and the second is PN 100. In the 1st version, there was a power trigger control to turn power nozzle off and on. on the handgrip. The second version, which is what i have, got rid of that feature. They brought it back in the AP280 series. The instruction manuals are a little different. They have same lady demonstrating the operation of machine, and they changed pictures to upgrade to new version of power nozzle and handgrip. Otherwise it's the same AP100 model. i enjoy using it. nice and quiet. follows me around. i do wish my version had the trigger on the handgrip of hose to on and off power nozzle. i shut cleaner off. remove power nozzle to another tool like the swivel floor brush, then turn it on. the reason i do this if you just leave cleaner on, and take out the power nozzle plug that goes into bottom of wand area, the male prongs will shorten over time. i read this years ago, and i'm glad i did. I told my family member, it was different brand of vacuum, and the same thing happened the prongs would get shorter and shorter on the power nozzle cord, as the family member would just leave machine on and disconnect the power nozzle and do other things, like use the floor brush or just use the pipe end to clean behind furniture. I know this is an old thread, but maybe someone will look into it.
I have the SideKick and it works great. I've used a similar type of attachment, same idea, on another model, but once you put the brushes against the area you need to clean, like carpeted stairs, for example, the brushes just stop moving. I guess it makes a good lawn ornament. lol oops! :D
if it stop on contact with the area you need to clean then i would open it up and look for a new belt or maybe just needs cleaning
The Sidekick as well as the dusting brush should not be used like a scrub brush. Just go over area lightly and let the air do the work. The harder you press down the less airflow that carries the dirt to the hose.
That is also true press gently yes do not cut off the air flow or suction of the machine let the air clean yes
When I use the sidekick I use it very gently back and forth, and it picks up just fine. You have to be in a relaxed state, just back and forth. Thank you for the tips. Silly question as I own a Singer 401A Sewing Machine where I have to oil the machine, but does one have to do any oiling to the bearings, or anything. I do to powerhead once in a blue moon, when i give it a good cleaning, I lube the ends. I don't know if i should be doing this or not to the vintage AP powerheads or not. I'm so glad I can come here, and get information. This is a wonderful site for good chat, and learning.
check your power nozzle brush roller if it spins by hand no need for oil if its tight and dirty clean try again only oil when nessary
