Electrolux 2100 serial number F21417E Made in Canada. Not sure if this is vintage or contemporary.
The green power light is on, no other light is on.
I hit the power switch and it seems firm and clicks, but nothing happens the motor does not come on.
The bag switch seems to be working as the spring action is fine. That said when I remove the bag and close the now empty vacuum non of the lights other than the green power light comes on.
I tried rotating the control valve dial back and forth, it did not help.
Is there a way to access and replace the control valve without opening the main body of the machine? Can I just snap off the blue plastic mount on top of the machine to access the control valve? I as able to lift the dial off but that did not get me very far.
Any other ideas as to what I should do?
