Dirt Devil Broom Vac
That one looks real nice! It looks like a newer one to me because of the bag pattern. What model is it? Does it have any rust? The ones I have run across have some awful rust issues around the base plate and brush roll bearings so I'd advise you not to let it get near too much moisture.
The broom vacs can be loud without having any issues but I would check the fan to make sure it is not broken and make sure the belt is tight. The motor might also need a good cleaning and a bit of oiling. I should warn you though that these motors are not repair friendly and if you decide to dig in to the motor I can post some pictures and tell you how it should be done.
Hey that would be great.. Right now it doesn't get much use because as you can see I don't have any carpet.. *not much sense for someone who collects vacuum cleaners huh??? I would appreciate any help!
I'll take some pictures monday. For now I'll just give you a general overview of the disasembly procedure.
Small Dirt Devils tend to come in halfs. The side with the screw holes is the empty half. The other half supports the motor, switch, and wiring. To begin, you need to remove the 2 screws that hold the base plate in place. Then remove all of the screws on the left (I think) side of the machine. At this point you might want to carefully remove half of the Dirt Devil sticker on the top of the vacuum. If you want you can cut it in half where the two sides split. Then you can take one side of the machine off. This will expose most everything, including the motor, fan, stone shield, and handle support parts. From here you can inspect for fan damage. This is as far as an inexperienced person should go before things start to get tricky. I'll explain about motor stuff later.
Just for reference this model takes Dirt Devil style 2 belts and type E paper bags. Broom vacs did have attachment kits available but they are rare now. You can use Dirt Devil hand vac attachments if you don't mind a 3 foot hose. You can check on ebay for the attachments and I recomend totalvac.com for bags and belts.
Piece of advice!
I had one of those Broom vacs at one time and I had it in the shop twice to have the switch replaced. Go easy on the switch! They are fragile! The third time it went out, it was beyond repair and I had to trash it :(. I bought mine brand new and it was pretty loud right out of the box too.
I've got one of those!
But the pattern on my machine's bag is different...
I got it brand new, back around maybe.. 1992/1993 or so?
I always liked how tiny it was... I used the hell out of it for quite a while, then just haven't touched it much since. But, oh, I wanted one of those in the WoRsT way! I somehow convinced my parents to get me one. :) I, too, had trouble with the switch. My grandfather, who was somewhat mechanically inclined, "helped me" take it apart and fix it. There was a loose wire, if I remember correctly. But, I haven't had a problem with it since-- although, I haven't used it with any regularity of course. Maybe I'll pull it out and give it a run one of these days.
~Fred
Switches
The Dirt Devil broom vacs used two different switches, one was a pushbutton and the other was a small rocker switch. I would assume that it is the pushbutton switch that causes trouble.
switch
mine was the push button switch.. my broom vac was one of the first made as it didn't have the adjustable handle and it had the smaller bag on it.
burning smell
I dated someone who had one of those Dirt Devils. I used it. The other day,
i got one . turned it on. There is a TERRIBLE burninng smell. It lasted for hours. This might be just "art". As ye know, I'm HOOVER all the way. I also have a tall-bag, 2 toned handivac, not as bad, but a 'smell". I liked those handivacs AND have 10 Pixies.... am I nuts?
Be kind
The Dirt Devil Broom Vac came in blue, also. If I get some spare time (Ha! What's that?) I will scan a spec sheet and post it. I would love to find that model as it would be more "rare"! I do have an attachment set brand new in a box unopened for my red model.
These machines are quite loud. They work well, however, one would have the tendency to believe that these machines should have the same motor as the hand-held Dirt Devil, but that is not the case.
Louis
John,
I believe in collecting what you like, even if it means doubles! That's what makes the club interesting. I have five Kirby Tradition models and only two of them are exactly alike. The other three are different and distinct in more than one way from each other. And besides, if it's blue...I gotta have it! Don't ask why. I simply don't know why. Does that make me nuts? Ahh..go ahead and say it...I have think Italian skin! LOL
Luigi!
Louis
As a Royal-Dirt Devil broom vac and hand vac collector, I would love to see the spec sheet for the blue model. I am also aware of a black model but have never seen one.
I have the blue hand vac that would match it, and have seen many of those but the broom vacs are far rarer overall. These days you would be lucky to find a red one in good shape.
The motor is the same design as the hand vac but more powerful on most occasions. Later hand vac models have the same power as some broom vacs at the 3 amp level.
By the way, does anyone have a spare brush roll sitting around? I could use one.
Well, I'll take one of each! Those things are slick looking. This also poses a problem because I thought there was little difference between the 733 and 737 and now I realize there is a big difference. Now I have one more rare Dirt Devil I need to find. Great! I also never knew about a pro series stick vac so I'll have to keep an eye out for all of those too.
As far as Dirt Devil spec sheets, if you have any more I'd love to see any and all that you have. Since you seem to be a great resource with this paperwork, you woulden't happen to have spec sheets on Royal metal hand vacs from that time period, or any time period for that matter? I'd love to see one of those.
burning???
should I look into repairing? It IS cute. sad reminders of an X in Jersey, but............... And, by the way, I live in a VERY Italian town. I LOVE Italians, well, some more than others. And, I have "doubles" of about 15 HOOVERS, plus the 10 Pixies. Thanks for the encouragement. John
I used to run across those red ones all the time at thrift stores back in Calgary. I had the stick vac with the triangular nozzle for awhile but gave it away. It was way too screaming loud for me
There's something about Flaming Red Dirt Devils that makes me see red. So I was happy to drag home this blue bagged one with the heart shaped corner brushless nozzle. Kinda cute in a kangaroo way. :-) On the backside are slots & holders for crevice tool, upholstery brush, dusting brush and wand extension. All I have is the wand.
Another of the free curbside gleans from Thorndale, a Dirt Devil Swivel Glide Platinum with rear casters rather than straight wheels, it's up and running again.
When I was at Ellison's Vac shop this aft Bill had one just like it in for repair...
The suction through the brushroll and bag chamber are fantastic. But there doesn't seem to be any mechanism for diverting full suction mainly to the hose when it is wanted and used with the tools (like Hoovers with the plug-n hose or a sliding door across the brushroll inlet on Cleaning Tools setting). Because of this the hose & tools are more of a dubious affectation than of any real use. Can anyone explain what I'm missing?
Certainly nowhere near the high quality thick plastic and internal ribbing as a Hoover upright bagged of similar 'vintage'.
Hoover wins again.
No wonder it's Preferred. :-)
Better construction & engineering and a more Royal Blue.
Much more all around useful - when the hose is plugged in it blocks the air passage from the brushroll admitting full vacuum force to the hose.
There's the Hoover Elite Preferred again...
I'm just as enthusiastic about that machine as you are! The Hoover Elite Preferred wins over all my vacuums, too. But, it can compete with a friend's Hoover Elite 350 that he wants me to fix for him. We are going to the vacuum store tomarrow to buy a piece that holds the motor down on the left side that broke.
