Convertible Maintenance Questions
hooveru4089
CT
I am going to be replacing the top sleeve bearing on an older Convertible with the original 2-speed motor. Would you advise lubricating with 3-in-1 before installing or are they ready to go out-of-box? Also, I keep losing the small triangular spring clips that hold the brushroll bearings in place. I have been making some out of old springs with pliers and wire cutters but I was just wondering if snap rings would work.
Thanks.
dont replace the bearing. just oil it. ive serviced many convertibles over the years and i find original top sleeve bearing to be better quality and less friction than the new replacements. i would only replace it if the bearing is scored from grease or a bent armature (both ive seen but extremely rare cases)
I should also mention that I will be replacing the carbon brushes. I noticed that the new ones have ridges on the seating surface. Do these just seat themselves while running? This is my first time replacing brushes on an electric motor before so I am curious.
Are you working on the same machine you discussed in your link? I didn't read the entire thread, but I gathered that you are trying to eliminate unexpected motor noises after the vacuum sits unused for a while.
My experience has been that the culprit for such a noise is usually the ball bearing, not the brass sleeve bearing. I know it's always tempting to try to lube or replace the sleeve bearing (because it's cheap/easy, right?) but after doing so, I find the unwanted noise usually persists.
The best solution I have come up with for addressing the noise, then, is to either lube or replace the sealed ball bearing. On Hoover vacuums, this usually involves drilling out the rivets which hold on the steel retaining plate and replacing the ball bearing. Simply drill out the rivets and slide out the bearing.
Now that the bearing is free, you can pry off both the rubber seals, blast the bearing with break cleaner, dry it thoroughly, re-pack it with high-temperature grease, and press the seals back on. This will fix the noise, however you still can't "roll back the miles" that were put on the bearing--it will never be as good as new. Much better is to simply go to a bearing shop (or shop online) to buy an identical replacement for only a few dollars. If you look hard enough, you will spot a combination of a few numbers/letters on the bearing. This is the bearing's "size." It is standardized; you do NOT have to buy a "Hoover" brand bearing. Hoover doesn't even manufacture their own bearings. They simply buy from a bearing supplier just like you.
Popping in a brand new bearing is the way to make it work like new again. Now simply find suitable rivets or screws which can re-fasten the lower bearing retainer plate and...voila! Smooth operation again!
See below for some pics. I have done this to my Concept One U3317, and I suspect the same can be done for you Convertible. I put in a brand new sealed ball bearing and three new blind rivets. Washers were added as reinforcement to keep the rivets from possibly pulling through the bearing retainer plate as I installed the new rivets.
Disclaimer: Attempt this only if you are sure you can drill out the rivets without ruining the base or bearing retainer plate AND if you are sure you have the correct hardware to re-assemble everything. You do run the risk of ruining things if you do it wrong, however, if properly executed, this service produces great results. I know it sounds like a lot of work, but if you have the right tools and hardware, you can get it done in a matter of minutes.
Good luck, and let us know how it works out.
Yes, this is regarding the same unit.
In the thread, I posted a picture of the bottom bearing from inside the motor. The bearing does turn freely and does not have any noticeable play from side to side.
I do believe this machine has not been used much as the outer bag has no major rips and the zipper and base paint are almost immaculate.
The best way I can describe the noise is that it sounds like there are pieces of sand or tiny pebbles occasionally scraping the armature. This is why others' speculations of bad carbon brushes made sense to me. I have pictures of them in the other thread as well. As I said, other than this, the machine runs absolutely perfect.
 The brushes will have to seat themselves and unless you use an armature/commutator 'stone' there will be a lot of carbon dust all over.  You can Youtube the process, as it's not hard to do...just have to be mindful of the LIVE current in the armature.
Kevin
Good to know!
I just checked some videos out. Most of them demonstrated the method of turning the armature by hand with sandpaper wrapped around the commutator to sand the brushes to shape while a few described the process of turning the motor on a lathe or running it. Which is more appropriate for these motors?
It's more accurate to chuck them on a drill and use emery cloth. You don't need to spin really fast...in fact you really don't want high RPM's until you've done this a lot. And like you saw in the vids, don't let the space between the commutator bars fill with trash....clean them out.
When your brushes seat themselves, they will generate a lot of carbon on the commutator....sometimes enough that it looks like you never cleaned the commutator. That's why I suggested seating the brushes and then coming back and cleaning the commutator again.
Basically, you want the brushes seated and the commutator shinny. That's your goal and can be done in different ways.
Kevin
I'll give the drill a try!
Interesting that you recommend using emery paper. Most other suggestions have been to avoid emery and only use garnet or wet/dry as they do not contain aluminum. I do have 180 grit garnet, which I hope is not too coarse but I'd be interested to hear your take on using emery paper.
Also, are you suggesting that the commutator be sanded again after the brush seating or should I use solvents to clean it?
180 grit anything is FAR too coarse to polish a commutator. 2000 grit wet dry sandpaper or use the seating stone and put the armature into a drill chuck and spin it that way. if you use anything under 1000 grit to polish a commutator, itll score it and keep the carbons from making proper contact!
Absolutely, nothing coarser than 1000 grit wet & dry paper. Use the stone and you won't have to worry about the paper/type.
You can clean things with denatured alcohol.....you don't want to remove any potting finish on the armature itself.
Kevin
Thanks for the tips!
I did use 220 at first just to remove residue, but I will finish it off with 1000+ before seating the new brushes.
Is denatured alcohol the same as isopropyl?
No, it's a lot stonger. You can find denatured alcohol at places that sell painting supplies or a good hardware stores....pretty common chem.  Cleans up vacs especially well, even the cord.
Kevin
I'll have to get my hands on that stuff. Do you soak the commutator in it or apply it with a paintbrush or likewise?
Denatured alcohol is pretty much just ethanol with enough methanol, pyridine or other chemicals added to make it toxic. Home Depot should carry it. 91% isopropyl alcohol or 91% ethyl rubbing alcohol should serve roughly the same purpose.
There's no comparison between the cleaning properties of <a name="start_35654.383160"></a>isopropyl alcohol and denatured alcohol. Just ask anyone who has cleaned tape deck heads with various chemicals.
No, don't soak the armature in denatured alcohol......paintbrush would be fine....always test the potting finish to make sure it doesn't start to come off....it shouldn't if it was done thickly.
Use the mechanic nitrile gloves when using chems...they're skintight and offer excellent flexibility.
Kevin
