Yes, they did. The specific front and rear bearings continued to be used even after Kirby changed the motor design with the 1956 model 516, up through to the 1970-73 Classic 1-CR.I recently picked up a Canadian 509. It appears the front bearing is riveted into the bearing plate. Is the correct bearing number 1160? Did US models also use a riveted plate? Thanks
View attachment 170103View attachment 170104
Midway through production of the 1951 model 511 (S/N 383346 and earlier had the riveted plate; S/N 383347 and up had the revised screw-on plate).Thanks. When did they stop using the bearing plate that's riveted together?
