Brushroll - When to Replace?
danemodsandy
Hello All:
Another of Sandy's burning questions here! This time, it concerns brushrolls in power nozzles.
I have two vacs, one a Lux Model L with a PN-1, that don't groom carpet as much as I'd like. The brushroll bristles don't appear unduly worn on either unit, and both have bristles that protrude a little bit from their slot on the bottom of the power nozzle. But - I'm not getting that "fluffed up" look to the extent I expect with the use of a power nozzle.
I'm wondering if anyone has a handy-dandy guide to knowing when to replace a brushroll. They're expensive enough that you wouldn't want to replace one that doesn't need it, but cheap enough that you'd gladly replace one if it would make a difference in performance.
I'd be very grateful for any guidance! Thanks in advance.
On the L shaped Lux nozzles, I find that when they've lost 1mm, a change out is worth it. Normally, the L shaped brushes start out at 9mm (millimeters) in length.
On some power nozzles (not sure if the PN-1 is one of them) there is a plate on each end of the brush roll that can be rotated 180 degrees when the brush roll is worn and that will cause it to be lowered enough that you can use it for sometime - sort of like getting 2 brush rolls for the price of one. The method I use to tell if the brush roll is at the correct height is to turn the power nozzle over and then take an index card on its end so that it is touching both sides of the plate surrounding the brush roll. Then pull the card the length of the brush roll. If the bristles do not touch the card then it is time to be replaced (or turned over).
Gary
Gary,
You can rotate the bearings on the PN2 or in Canada, the AP Lux series PN, which will give you longer bristle brush life.
